1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
Old 03-15-2016, 07:06 AM
  #221
Tjabo's Avatar
So excited to see what you find about the 88mm turbo when you start tuning!
Old 03-15-2016, 09:56 AM
  #222
a4ls2goat's Avatar
So the run down of parts for future reference.
2004 5.3L. 862 heads.
Ls1intake manifold. Stock TB
216/220 TF cam
ebay headstuds.
Ls2 timing chain
5.3 headgaskets
On3 88mm turbo
3inch intercooler and piping
godspeed 60mm wastegate
2.25ID hotside. T4
3inch downpipe out the fender
80lb siemen injectors
aeromotive regulator with return
ebay fuel rails
aem bosch 044 style pumps X2
1/2 feed
3/8 return
12gal fuel cell.
Th400 fresh rebuild
REVMAX 3600 stall
41.25 inch steel driveshaft with 1350 ujoints
8.8 rearend
3.15 gears
mazda stock diff mounts welded on the 8.8
26x10.5x15 et streets
15x8 4.5 BS summit wheels
Microsquirt plug and play harness with 3 bar map sensor.
Old 03-15-2016, 12:43 PM
  #223
krazy4's Avatar
Originally Posted by a4ls2goat
Lol. Did it in about 1hour or so. I just sprayed it and said **** it. Lol. Took 2 gallons to do it.
Haha that's my style right there.
Did you mask it off at all or just peel the plasti-dip in the places you didnt want covered?
Old 03-15-2016, 01:01 PM
  #224
a4ls2goat's Avatar
yea, just covered the wheels and engine bay.
Old 03-15-2016, 05:37 PM
  #225
Turbo D's Avatar
216/220 TF cam
ebay headstuds.
5.3 headgaskets
On3 88mm turbo
2.25ID hotside. T4
ebay fuel rails
1/2 feed
3/8 return
12gal fuel cell.
Th400 fresh rebuild
REVMAX 3600 stall
8.8 rearend
3.15 gears
The only thing I could see being an issue is the 3" downpipe, since your exhaust wheel is 3.25" it could end up being a choke point.
Old 03-15-2016, 05:40 PM
  #226
a4ls2goat's Avatar
The downpipe is like 3 feet long. Lol. Well see if it becomes a restriction
Old 03-15-2016, 05:51 PM
  #227
3 window's Avatar
What's the story on the rear wheels? Gloss plasti dipped, powdercoated or painted?
Old 03-15-2016, 06:19 PM
  #228
a4ls2goat's Avatar
Gloss plastidipped.
Old 03-15-2016, 11:05 PM
  #229
a4ls2goat's Avatar
Took it for a ride around the block.
Cant get the computer to connect to the ecu so i just ordered another conector from efi life.
Oil return flange made by my friend.
Old 03-17-2016, 02:16 PM
  #230
kwrench61's Avatar
No BOV??
Old 03-17-2016, 04:57 PM
  #231
a4ls2goat's Avatar
no BOV
Old 03-18-2016, 01:06 PM
  #232
svslow's Avatar
I had the same problem the other day. Serial to USB adapters are awful.
Old 03-18-2016, 05:48 PM
  #233
a4ls2goat's Avatar
Did u figure it out
Old 03-18-2016, 07:21 PM
  #234
a4ls2goat's Avatar
Got it to connect.
I have the rpm jumping around from 2k to 1500rpm anyone know where to start to fix this idle issue?
Old 03-18-2016, 07:32 PM
  #235
dirtylark71's Avatar
Ground maybe? Are the browns grounded to the head?
Old 03-18-2016, 09:40 PM
  #236
redss82's Avatar
do you have the addon to control the iac valve if not that needs to be plugged up/ epoxied shut
Old 03-18-2016, 10:24 PM
  #237
Forcefed86's Avatar
I believe you can take the idle valve apart and unscrew the plunger all the way. Then put it back together and it should stay that way as long as you don't have any power to it. Maybe stack washers up on the shaft so It can't retract again under boost.
TB set screw backed out enough to keep the TB closed?
Old 03-19-2016, 07:30 AM
  #238
a4ls2goat's Avatar
The idle valve is there but not connected, would it still cause an issue even though its not connected?
And yea, tb is all the way closed
Old 03-19-2016, 09:42 AM
  #239
kwrench61's Avatar
Sounds like it's hunting for idle and can't control it. Plug iac in and see what it does. I believe off/unplugged position is wide open which may explain.
Old 03-19-2016, 09:49 AM
  #240
a4ls2goat's Avatar
im running microsquirt plug and play ecu. it doesnt use the iac
Quick Reply: 1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
