what did you do to your camaro today?
#884
Finally got my LPP/XS Power headers on. The Speed Engineering Y pipe I was sent needs adjusted because it hangs about 3" off the ground on the driver's side, but it is going to an exhaust shop for that. Tired of screwing around with jackstands and ratchets. The steering shaft also contacts the header, so that's my next issue to fix.
The car sounds fantastic with longtubes and GMMG though. Has the 2500 RPM rasp. Otherwise the sound is nice and smooth, and she screams in the upper rev range.
#892
I literally got out of the car like I had pulled in the driveway. Concussion, sore neck and back but I'm fine. I'm looking at rollers now. I have my eye on a 2000 Z28 roller in Georgia. Might pick it in the next few days.
Motor fires right up. Of course I shut it off right away. Can't wait to get back out there.
#893
These cars have definitely saved a few lives.
#896
This has been over the last month, car is sitting out back on jack stands. Dropped the tank and found the gear clamp on the tube from the fuel pump was loose and shooting out fuel and when that was back together the FPR was leaking as well. Ordered external FPL, lines and fittings. While I was waiting pulled the intake and port matched as well as filing off the logo and painting it and the lid and lid base a bed liner black. Now I have the external regulator mounted and putting the lines together. Not really happy about the way it looks. May change it around later but for now I still need to drop the exhaust and add a couple of brackets as well as put in the driveshaft loop.
