427 Procharger F1A build
#42
Nice numbers and nice pass...
Have you ever made a pull without the air hat/filter on it?
I guarantee you, that air hat is killing atleast 50hp...
F series blowers (all blowers for that matter) hate having anything with bends in front of them...Especially a tight 90* bend..
On the street there is no choice but on the dyno and on the track, I'd pull that **** off and watch that wideband...
Bad *** car man!
Bad *** car man!
#44
Bad *** car man!
Bad *** car man!
I have always run with a filter. There is too much debris at the tracks around here to not run one.
You do have me intrigued though, I may have to try it on the dyno sometime for a number though.
#48
LS1Tech Sponsor
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/520x390/bob2_b761e1e278d8059b10a7f9db1c4a5101ecb50daf.jpg)
Here is how we ran a larger air filter on my Camaro. Bob
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#49
I've had the Aster bracket for awhile, but it won't work with my evans wp. It doesn't clear the pulley. I may give it another go. Thinking of trying a wp pulley from a sbc. I also have a 427 but with the D1 maxed out I'm ony getting about 8psi out of it. If I could get the aster setup to work I want to go with the F1 as well.
#50
LS1Tech Sponsor
#51
I think the LS2 pump would probably be fine. I knew that's what I needed. I have the MID block and the evans pump is what they recommend. I have a lot invested in the engine and feel I should stick with that pump. I have talked to Evans Cooling a few years ago and they wanted a crazy amount of $ to custom make a pulley. I probably should have just done it. I'm hoping I can get an off the shelf pulley and modify it to work. March performance has one I think might work for me, otherwise I'll have to have something made.
Appreciate your reply
#52
LS1Tech Sponsor
You're welcome. Hopefully you can make it work. Bob
#54
I just replaced my K&N 9" cone style air filter with a S&B equivalent 5102 filter on my Monte (cost 40 bucks less). I can tell you by the extra air that escapes the Procharger Big red valve that this filter is definitely letting more air through. I haven't taken it out yet to check and see if I'm gonna have to add more fuel.
#55
UNDER PRESSURE MOD
#58
After looking at the logs the engine also got hot during the run and tune pulled 3-4 dergee of timing in 2-4 gear. There is a lot more left in it. Time for a new rad and some more meth.
Never had a opportunity to run the car again. Next year I guess.
#59
fwiw on my 900whp D1SC c6 vette, a blox velocity stack with AFE custom filter right on the front of the blower, no tubing, bends, etc. gained 3whp by removing the air filter and going with bigger/better velocity stack. 3whp is approx nothing at 900whp so I consider it a wash. This D1 blower is certainly at the very edge of what it's capable of and limiting the power but I was surprised and I think if you can get a straight stack with filter on the front of your blower/turbo then you're not giving up much or anything by running a filter
#60
If you don't mind me asking, what's your pulley combo @ 900whp ?
