427 Procharger F1A build
Old 06-01-2016, 01:51 AM
2002gt's Avatar
Default 427 Procharger F1A build
Well since I completed my build I figured it was time to do a build thread.
My car is a 02 Som Trans Am that I have modded over the last several years.
I purchased the car in Texas. It was a featured MTI (Houston) car that I always drooled over and was finally able to buy.
The car had all of the bolt ons and was just in need of a engine. So round one of mods was a complete LS7 based 440cu long block from Vengeance Racing.
The car made 580 rwhp and ran 11.1 @ 126 mph, with this setup.
That was fun for a couple years and then I wanted more. Which lead to my current combo.
- ERL 427 Superdeck I short block
- Trickflow 235 cc heads
- Vengeance Racing ported Fast 102 mm intake and throttle body
- Vengeace Racing custom blower cam
- Procharger F1A supercharger with 7.65 crank pulley and 3.55 blower pulley. 15lbs
- Procharger race front mount intercooler kit.
- Kooks 1 7/8" headers with kooks 3" true duals
- ID1000 injectors with Lonnie's 1000 hp fuel system upgrade
- Snow meth Injection
- Tick Performance T56 with McLeod RXT
- Moser 9" with 3.70 gears
After fighting some issues I am starting to see the results that I hoped for.
The new combo dyno numbers were 830rwhp and 795 rwtq on a mustang dyno.
Here are a few picks during the build and of the finished product.
I wanted to give a shout out to a few ls1tech venders that were awesome resources during my build.. They we're all awesome to deal with.
Ron at Vengeance Racing
Sean at ERL Performance
Bob at Brute Speed.
Cheers.
Old 06-01-2016, 05:30 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Beautiful '02! Thanks, I appreciate it Harley!! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-01-2016, 06:40 AM
conan's Avatar
Very nice car... Congrats
Old 06-01-2016, 07:37 AM
josh4ku's Avatar
How much boost? What's the compression ratio? Pump gas?
Old 06-01-2016, 10:29 AM
2002gt's Avatar
I am running 15.2 lbs of boost. The engine is 9.5 to 1 compression on 94 octane pump gas with 50/50 meth mix.
Old 06-01-2016, 10:43 AM
LS1Tech Sponsor
Originally Posted by 2002gt
I am running 15.2 lbs of boost. The engine is 9.5 to 1 compression on 94 octane pump gas.
What is your elevation there Harley? Bob
__________________
Old 06-01-2016, 11:09 AM
2002gt's Avatar
Our elevation is about 3000 feet actual. It is almost always 3500 feet corrected during the race season.
I found I had to spin my procharger much harder than most individuals were at lower elevations on ls1tech.
Old 06-01-2016, 11:12 AM
forcd ind's Avatar
Clean build
Old 06-01-2016, 11:15 AM
LS1Tech Sponsor
That makes a big difference indeed. An F-1A-94 would be a direct swap dimensionally for your F-1A and is good for several hundred more hp. It is softer down low than your F-1A, but with your combination that shouldn't be a factor. Bob
__________________
Old 06-01-2016, 11:30 AM
AnotherWs6's Avatar
Planning on taking it back to the track anytime soon?
Old 06-01-2016, 12:17 PM
2002gt's Avatar
I do plan on going back to the track ASAP to get some numbers. I will post the results when I get them.
Old 06-01-2016, 12:23 PM
2002gt's Avatar
I might have to look into the F1A-94 upgrade in the fall. As for right now I couldn't be more happy. I have street car with AC and 830 hp that I can drive anywhere.
Old 06-01-2016, 12:27 PM
Rise of the Phoenix's Avatar
Great combo! A big cubic inch LSx with a Procharger is the ultimate goal for me.
Old 06-01-2016, 04:11 PM
Detoxx03's Avatar
Beautiful car.
Old 06-02-2016, 02:47 PM
LS1Tech Sponsor
Yeah I know you had asked me about a larger head unit awhile ago, that's why I threw that out there. 830 hp, a/c and a very clean T/A is a great combination! Bob
__________________
Old 06-03-2016, 09:03 AM
josh4ku's Avatar
Where did you get your intercooler piping, and what intercooler is that?
Old 06-04-2016, 01:11 AM
2002gt's Avatar
It is the Procharger fbody front mount intercooler kit. It is the 1300 hp race intercooler, I believe. I got the kit from Brute Speed.
It is worth the money the kit dropped my iat 30 degrees and I picked up 2lbs of boost over my Cxracing intercooler.
I just swapped the 3 top tubes in the kit for a cleaner look. I replaced the 3 top tubes with a 1' by 1' aluminum 90 degree bend and a Vibrant 4" to 3" reducing 90 degree bend rubber elbow.
I had the aluminum bend cut and flared to match the other pipes in the kit.
Then everything was powder coated black to match.
Old 06-04-2016, 08:46 AM
No Juice's Avatar
What did you use for the blower inlet?
Are those fog brackets part of he bumper support or did you make them?
Old 06-04-2016, 11:02 AM
2002gt's Avatar
I am running the procharger truck hat with a large filter.
The supplied larger procharger cone filter does not flow enough cfm for half of my combo. The procharger filter was actually sucked in before I replaced it.
New setup.
This filter flows 1700 cfm. Which what I needed.
Old 06-04-2016, 07:30 PM
Jimbo1367's Avatar
do you recall the filter dimensions or brand & P/N
Thanks,
Jim
Quick Reply: 427 Procharger F1A build
