Lets see those drag setup.
#1025
The tires will certainly fit but if you are talking about a half inch clearance between the slick and the bottom of the rear bumper the you should get adjustable lower control arms if you haven't done so already. Then you can center the rearend equal distances from the front side fender and the rear bumper. Remember too your slicks will grow taller on the big end at speed so I wouldn't want any less than a 1/2 inch clearance on either side.
#1038
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1325/dsc_0569_218e1d367a48b5672cec42551a4ce39fe8511a26.jpg)
On the strip at Royal Purple in Houston, Texas
