Lets see those drag setup.
Old 09-01-2016, 05:11 PM
  #1021
TexasVortexx's Avatar
I Like mine low
Old 09-01-2016, 05:25 PM
  #1022
BOLO's Avatar
Originally Posted by Stardust
Updated to Alumastar 2.0 up front.
Bad *** looking LT1! Especially with that hood.
Old 09-02-2016, 03:19 AM
  #1023
badfbodyz's Avatar
Originally Posted by Photochop
Dang Badfbodyz, did you bring the front down even more than the other pics? It looks killer!
Yes I went with Strano/Koni setup all around with the rear hose mod
Old 09-02-2016, 08:56 AM
  #1024
1_slow00z28's Avatar
Has anyone had to raise they're car back up to fit a 28x10.50. My car is lowered right now and i am having some issues being very close to the back bumper
Old 09-02-2016, 07:06 PM
  #1025
The tires will certainly fit but if you are talking about a half inch clearance between the slick and the bottom of the rear bumper the you should get adjustable lower control arms if you haven't done so already. Then you can center the rearend equal distances from the front side fender and the rear bumper. Remember too your slicks will grow taller on the big end at speed so I wouldn't want any less than a 1/2 inch clearance on either side.
Old 09-03-2016, 09:42 AM
  #1026
I ended up trimming the rear bumper of the car a tad because I wanted more clearance that what was there thanks
Old 09-06-2016, 09:28 AM
  #1027
dsadsdaiouser's Avatar
Old 09-06-2016, 04:00 PM
  #1028
Old 09-06-2016, 07:49 PM
  #1029
badfbodyz's Avatar
So many clean rides in here
Old 09-07-2016, 03:31 PM
  #1030
Jtm2085's Avatar
Shitty picture, but you get the idea.
Old 09-09-2016, 04:12 PM
  #1031
badfbodyz's Avatar
Old 09-09-2016, 07:20 PM
  #1032
Oh that's nice. Is your rear narrowed a bit?
Old 09-10-2016, 04:16 PM
  #1033
badfbodyz's Avatar
None. 15x10 7.5" backspace
Old 09-10-2016, 09:28 PM
  #1034
BOLO's Avatar
^^Thats the best 15" wheel offset I have ever seen on a stock width rear end. It does look as if it has a narrowed rear end. Nice looking fire chicken btw.
Old 09-11-2016, 07:07 AM
  #1035
badfbodyz's Avatar
^ low pad rts FTW
Old 10-05-2016, 04:17 PM
  #1036
BOLO's Avatar
Here's mine
Old 10-05-2016, 10:21 PM
  #1037
455GTO's Avatar
Old 10-06-2016, 09:15 AM
  #1038
Groesbeck's Avatar
Default Artic White 2001 Z 28
Originally Posted by Intimidator_SS
just like the title says. i wanna see some drag strip setup. i just got some prostars 17x12. they dnt make those anymore. and i wanna see if i should keep them or go with a different setup. Post pics
On the strip at Royal Purple in Houston, Texas
Old 10-07-2016, 02:26 AM
  #1039
badfbodyz's Avatar
Originally Posted by BOLO
Here's mine
Nice looking ride
Old 10-07-2016, 08:57 PM
  #1040
6spdg37s's Avatar
setup for now. spring wil do skinnies to match
front is lowered on 275# qa1 single adjustable coils
Quick Reply: Lets see those drag setup.
