LQ4 into a 3rd Gen/1972 Nova
Old 12-20-2016, 08:10 PM
  #1641
frojoe's Avatar
No et goal as I'm not a drag racer, but hp goal is obviously just moar. I'm happy to fabricate and replace pretty much anything on the car down the line, but pulling engines to rebuild is about as low on my list of likable tasks as it can possibly get.
I figure I may as well go bigger now while I'm at it, to support future mods. Turbo will be iffy but I can reevaluate that later.. at least spool will be quicker. I'm leaning towards keeping the LQ4 block and boring 0.030" as it's pretty much a sure thing, and that extra $1k will go a long way towards that stainless 3.5" oval dial exhast I still need to make. In the end, if I happen to end up with an engine bigger than Marktainium's.. even if just by 0.5cid, then that's a win.
Old 12-21-2016, 03:00 PM
  #1642
-TheBandit-'s Avatar
I see no reason to get a newer aluminum block or bore larger than you need. A few more cid and/or a little less weight is not worth the money. I think you'll be better served spending that money on machine work and stronger components so you can reliably run a tad more boost to make up for the few cid difference. Unless something is wrong with your block, I don't know what you'd be gaining?
Old 12-21-2016, 07:10 PM
  #1643
00duvall's Avatar
If ur bores are good i would hone it put forged rods and pistons in it. As for heads get thicker deck casting head and head studs.Save money and can crank up boost. Not sure what cam u are running but that is something to change during down time.
Old 12-21-2016, 07:18 PM
  #1644
frojoe's Avatar
Engine is currently a 365cid 4.005" x 3.622" rebuild with Wiseco -11cc pistons, Compstar H beam rods, Eagle forged crank, Patriot springs, Comp pushrods, LS9 head gasket, Tick custom grind medium turbo camshaft, and ARP 2000 everywhere. So I'm familiar with building it, and I'm not trying to do things on the cheap, more like just cost-effectively/realistically, while still building it a bit bigger for the future. I think I'm prettymuch sold on keeping the block, and stroking to 4" and boring it to between +0.010" and +0.030".. haven't decided that yet. I like the idea of more hp with the boost lowered a bit, and even more hp with same boost as now (16psi).
I'm in talks with my boss's previous employer, which builds turbos locally and can get wicked deals on Garrett direct or hybrid turbos. One regular direction GT3582 and one reverse direction GT3582 may be in my future.
Old 12-21-2016, 07:55 PM
  #1645
00duvall's Avatar
Got ya i was thinking u had a stock 6.0.I would think u would be better off to buy a short block. Time u get it machined buy new pistons and crank,crank bearings, cam bearings then if u have to pay to have it assembled.Ur going to be close to cost.I think i seen treperformance has 408 short block for 3499.The also have a dart 427 on sale for 5599. We never stop wanting more hp.Sale what have and go big.lol
Old 12-21-2016, 09:23 PM
  #1646
Marktainium's Avatar
Hmmmmmmmmm..........
Old 12-21-2016, 11:33 PM
  #1647
frojoe's Avatar
I mean.. uhh...hmm..... what?
Old 12-22-2016, 07:12 AM
  #1648
gofastwclass's Avatar
Evil! Hahaha
Old 12-22-2016, 10:50 AM
  #1649
frojoe's Avatar
He has a project plane, and a racecar Miata, and a Benz E55 wagon daily driver.. so I have to have at least something that's just a bit better than him. Even if just by a wee bit.
Old 12-22-2016, 02:04 PM
  #1650
Jimbo1367's Avatar
I'm just glad you guys haven't resorted to whipping out your dicks, LOL. YET
Old 12-23-2016, 01:55 AM
  #1651
frojoe's Avatar
Hah Jimbo.. we're good friend, but not THAT good of friends.
Did some screwing around looking at turbo stuff tonight, for a 408cid engine with a pair of Garrett GT3582 turbos (66mm inducer compressor wheel), I drew a theoretically-perfect line thru the compressor map to reverse-calculate the required boost-per-rpm for those turbos on a 408. Purely looking at the cold side/compressor airflow, they seem to be a good match for the 408 efficiency-wise for realistic boost and pressure ratio (AKA boosted charge air temp)..
Old 01-04-2017, 02:53 PM
  #1652
[/QUOTE]
Your graph shows a very laggy boost curve. I don't get it. My turbo's are essentially gt35's and I have full boost around 3500rpm. It also pulls until 6500 which isn't on your graph.
You have a nicer Bicycle than me...
Old 01-04-2017, 03:35 PM
  #1653
frojoe's Avatar
That boost-rpm graph is a reverse-engineered plot out of curiousity of what the compressor side wants the boost to be for a 408 in a most-efficient world.. it's not saying that the turbo won't spool quicker or reach full boost earlier, just that for that engine, for the turbo's to spool quicker would mean operating above/left of the efficiency islands.
Also you have PT6262's which are much closer to a Garrett GT3076 which has a similar compressor map but the island is shifted about 10lbs/min to the left, so for same boost pressure ratio, that boost is produced more efficiently at a lower rpm.
I'll update my turbo graphs on my home computer with a couple different scenarios and post those. I've been on Maui for a week.. which is perfect research time. I've gone thru multiple iterations of my engine rotating assembly, cold side, hotside, cooling, transmission, exhaust system, you name it. I've decided:
1) keep existing 6L iron block.. it's strong, everything bolts up.. money in the bank.
2) stroke engine to 4" but keep cylinder thickness reasonable. Maybe bore to 4.010" but try to just hone existing 4.005" if possible.. enlarge bore to 4.030" as last resort
3) keep single turbo setup for now, even tho PT7675 will be bit undersized for stroker.. more on that in a bit
4) rework one turbo hotpipe to allow thicker rad/fan stack in front of accessory drive.. this is a must address issue. Can't move intercooler forward so more clearance needs to be developed between current fans and passenger hot pipe. Also need to reroute waterpump inlet routing for more room.
5) new dual exhaust. Keep current 4" downpipe, rework the merge so instead of splitting into dual 2.5" it splits to dual 3.5" oval (2.5"x6" so it's equivalent to 3.5" round exhaust), routed up to transmission tailhousing area. Make new "3.5in oval" stainless exhaust from tailhousing back to dual 3.5" Dynomax mufflers under floor pan, then goes underneath the axle and straight back under the gas tank (heat tape and heat shields used) exiting straight back underneath rear bumper. Obnoxious, but easiest to route.
I've always liked the brashness of the layout of the 1970 Roadrunner "Hammer" exhaust (except for the refined nature of the rounded & polished oval tips) but with straight cut round stainless tubes instead, maybe painted flat black for more brutal/purposeful appearance..
After much thought, the future setup (which I'll be keeping a constant eye out from now on for discounted parts) is.. CTS-V manifolds welded to short schedule 80 elbows feeding 64/65 or 66/67 twins, Precision 46 wastegates and 3.5" downpipes that then meet up with the new oval 2.5"x6" pipes under the floorpan.
It's good to have a goal that I can constantly think on and tweak as I see deals and classified ads for things, and not make any impulse buys right now before I tackle other more urgent issues. The layout in my head should require zero "undoing" of work I plan to do this spring when the garage concrete heats up.. damn you Mark and your 2 post lift!
Old 01-04-2017, 04:02 PM
  #1654
Sounds like a game plan. I'll be interested to see where that copper in your oil is coming from. Try to build everything right and still things go wrong.
Old 01-04-2017, 04:54 PM
  #1655
Given that your rotating assembly was all new, a great place to lose oil pressure is the cam bearings, as you stated earlier. Did you replace them when you did the motor? Did you plasti-gauge the mains and rod bearings when you built it?
Not a fan of the under the axle exhaust. Have you considered sheetmetal work to do an over the axle exhaust? Even a side exiting oval pipe in front of the rear wheels or possibly integrated into the bodywork?
Old 01-04-2017, 05:47 PM
  #1656
Jimbo1367's Avatar
LOL. You two are so funny !!!
Old 01-04-2017, 06:13 PM
  #1657
frojoe's Avatar
Clint, it's too true.. but you gotta pay to play and sometimes you just get bitten I guess.
Mark, the cam bearings were new and installed by High Performance at the time the block has bored and honed to 4.005", decked 0.004", the main and cam bearing bore alignment was confirmed good and block cleaned. However I ran the rebuilt engine with the stock truck camshaft for a summer before replacing with a Tick turbo grind Comp cam similar to yours. I plasti-gauge'd the bearings and I recall them being on the looser side of the spec range but still within range, however I never recorded the values so can't look back on it. I'm chalking it up to warm oil and maybe strangely worn cam bearings. I'd like to be the one to rebuild again, but I've also contemplated having High Performance throw together the short block just for piece of mind on my end.. although I'd really like to just do it myself again.
Why don't you like the under-axle routing, other than it hanging visibly low from the rear as well as heat? To the best of my memory, with my ride height the bottom of the axle is near or above the centerline of the muffler outlet. The coilover upper shock mount crossbrace is right in the way, and the next tightest fit is between the upper control arm axle-side mounts and the OD of the coils.. it's effing tight in there even for 2.5" exhaust.. the shock mounts and cross brace would have to go up probably 2 more inches into the the trunk to be safe, and the shocks would need to move more vertical, but there's little room there until they hit the insides of the framerails.
For side exit exhaust, either under the rocker panels or thru rocker panels, there'd need to be some serious routing trickery to get around the front leaf spring perch as that's what my lower control arms mount to, and I need to put the mufflers in the stock floorpan recess location.. so some Z-shaped tailpipes for sure. Also don't like the same side in-out mufflers as that's not very straight-thru!
It'll be an other 3-4 months before I touch that, so plenty of time to discuss. The only option that's firmly off the table is turndowns after the muffler before the axle, as it's just too annoying.
Old 01-04-2017, 06:48 PM
  #1658
frojoe's Avatar
Kindof relevant to the exhaust tubing discussion, but more particular to the turbo hotside piping, I plan to keep the internal cross-sectional areas as consistent as possible, as every time the turbo exhaust is allowed to expand or contract via the internal area changing, then it has to slow down or speed up accordingly and that means losing exhaust energy. Also the plan is to make the distance between exhaust manifolds and turbine inlet as short as possible. This means a spreadsheet that tracks exhaust volume and cross-sectional areas to make sure it doesn't neck down between the head's exhaust port, manifold's collector, hotside piping, T3 turbo flange, then turbine inlet itself. So far using 2.0" schedule 40 piping (2.067" ID, 3.355 square inch area) matches exactly with a T3 turbo flange (3.356 square inch area). Once I acquire and measure CTS-V manifold primary and collector areas, I could adjust piping ID to gradually neck down to the T3 area. so that the exhaust velocity stays as consistent as possible, with a small increase in velocity only as it enters the turbine.
There's a very interesting (and long) discussion on turbo hotside piping ID vs flow and hp capabilities in this thread:
https://ls1tech.com/forums/forced-in...over-pipe.html
So same idea goes for the exhaust tubing.. no matter the turbos I end up going with for a twin setup, they'll have a 3" turbine outlet size which I'll smoothly but quickly expand to 3.5" downpipes, and would ideally keep that exact same equivalent 3.5" internal area for the entire length of the exhaust.. with as few bends as possible.
Old 01-09-2017, 06:24 PM
  #1659
The under axle exhaust route means you have to lay it low enough that at full droop you have clearance to the pipe, plus run-by, so depending on the topped out travel that may make your pipes hang pretty low. possibly in the leaves the muffler then bends down before going back up low. Now if you bottom out, does the net travel to ground clearance math work out?
This being said, with your coilover setup you may be totally fine because of the amount of travel you have.
When I renew my setup I will go to a minimum of 3.5" and will work my sheetmetal to get the over axle fit. I will also use the oval, and may as well tell you now, I'll work in electric cutouts tied into secondary fuel map.
Old 01-09-2017, 06:30 PM
  #1660
frojoe's Avatar
Quick Reply: LQ4 into a 3rd Gen/1972 Nova
