*The ulitmate street/strip build* F1C procharged trans am ws6 ~pic heavy~
Old 01-28-2017, 11:26 AM
josh4ku's Avatar
Originally Posted by ramairetransam
what did bmr say about the k member. Time for a umi
Not going to say much right now, Waiting to hear back from them on monday to see if they want to make me happy or not.
josh4ku's Avatar
Originally Posted by Firehawk441
Looks good.
Best of luck with it
Thanks!
Old 01-28-2017, 12:11 PM
customblackbird's Avatar
Nice build!
I run a racecraft moly kemember and it fit like a glove on my 3rd gen. Check them out! My next choice would be UMI. I don't mess with BMR or SPOHN. That's a lot of warp from welding yikes.
What line lock is that? I run a hurst anti roll and has worked great. Don't skimp and get a jegs or summit brand they are cheap knockoffs and fail right out of the box... ask me how I know lol.
Also on thr kemeber brake lines just rock plastic zip ties. Those worm clamps are gona run the powder coating off and cause rust.
How much boost you going to run? We are simular with our plans on what's appropriate for the street lol. 700hp is just about right IMO without needing crazy tires. I run about 12psi on my 5.3 with a centri and ported stock heads and custom 218/230 cam motion cam. Looks like your doing it right! Wish I could afford the S60.
Old 01-29-2017, 10:20 AM
josh4ku's Avatar
Originally Posted by customblackbird
Nice build!
Yeah I'm just going to make this BMR K member work more than likely. I already heave the brake lines all built for this k member now.
The line lock is the hurst. I just took the sticker off because it was going to be upside down the way we mounted it.
Not sure on the boost. The f1c has the 4.50" pulley with the 7.65" crank pulley. Guessing around 15psi or so not sure its hard to tell!
Old 01-31-2017, 05:57 PM
josh4ku's Avatar
Mounted the intercooler , bolted the engine to the k member. Had to remove the a/c compressor , procharger bracket and alternator to get the engine bolts installed. Not a lot of room with 2" headers!
Old 01-31-2017, 06:10 PM
Very clean!
Old 02-01-2017, 12:28 PM
josh4ku's Avatar
Looks good.
Thanks
Old 02-01-2017, 01:00 PM
conan's Avatar
Looking good man, what did you figure out with the BMR K ?
Old 02-01-2017, 02:01 PM
Super Hulk Smash
JakeFusion's Avatar
What water pump is that? Or WP pulley?
Old 02-01-2017, 05:27 PM
josh4ku's Avatar
It is the LS2 water pump, ordered it from brute speed when I ordered the aster bracket.
Old 02-01-2017, 05:28 PM
josh4ku's Avatar
Well bmr sent me a second one which was twisted also. They checked their stock and they are all the same! So I am going to make this one work with. Waiting for them to refund some of my money, I think they should refund half of my money! But they don't act like they want to do that. So it may get ugly.
Old 02-02-2017, 11:04 AM
conan's Avatar
That sucks to hear hopefully BMR will set you right if is their fault for the twisted batch of K-members. I would be looking for a full refund and going after another vendor. Good luck with it.
Old 02-02-2017, 11:07 AM
josh4ku's Avatar
Well I want to make this one work , I've already Spent a lot of time forming new bake lines to This k member. But I don't expect to pay anymore than half price for it this way!
Old 02-02-2017, 11:29 AM
Super Hulk Smash
JakeFusion's Avatar
I wouldn't run a twisted K-member. That's a safety issue.
Almost any of the "turbo" k-members are pretty similar. So your lines should work on any of them. PA Racing's Turbo K is very similar to that one.
Old 02-02-2017, 08:52 PM
For the guys intereted where the bmr k member situation ended up.
https://ls1tech.com/forums/suspensio...l#post19522948
Link doesn't work.
Old 02-03-2017, 08:37 AM
KyleLanter's Avatar
Looking good in for results. Also sucks about the k member I have a bmr turbo unit and it sits perfectly. Hope they square up with you on the issue.
Old 02-03-2017, 02:51 PM
ramairetransam's Avatar
They are a sponsor it must have gotten wiped away by the admins. Or the issue was fixed by bmr and he deleted the post.
Old 02-03-2017, 02:54 PM
josh4ku's Avatar
I felt bad to post a complaint so I deleted it for now, planning give them some more time Work it out.
Old 02-03-2017, 03:28 PM
  #39
josh4ku's Avatar
Just got off the phone with BMR. Found out the 1 mount tube was just simply welded on too high, I just have to grind it down a bit, the rest of the k member is just fine!
After actually speaking with the owner and working this all out I'm once again a happy customer thanks BMR.
Old 02-03-2017, 04:00 PM
  #40
Super Hulk Smash
JakeFusion's Avatar
I like that intercooler setup. That's the Bell 4.5" they sell? It's not on Huron speed's site, but is an upgrade on their turbo kits. What's the pricing like on that? Less than the ATI Unit?
Quick Reply: *The ulitmate street/strip build* F1C procharged trans am ws6 ~pic heavy~
