Th400 lokar push in dipstick.......how???
So i got my trans bolted up yesterday finally. But prior...i tried to install the lokar dipstick and it pushed in tight at first but then pulls out real easy or too easy. Im afraid at wot it might pop out....how have you guys using the push in style kept it in place?? Thanks. I can include pics in a little bit.
I have to use that same dip stick. I used some black rtv under the head and around the first oring to seal and kinda glue mine in. I also revamped the bracket with a pc of metal close to the handle and drilled a hole in it for one of them 1/4 inch pins that have the cam over ring on the end. So far tech hasn't said anything
