Scrapyard S10
Old 03-25-2017, 04:50 PM
  #201
Cyrperformance's Avatar
Heads came out really clean. I would say the oven cleaner that I've read was the best. Let them soak for about 30 mins then pressure wash. Springs will be here Monday, BTR Dual Platinum from LS1 Tech member.
Trunion upgrade showed up so those will be done today.
With all of the above done, I found my ARP head bolts were the newer short style which will not work with this block. Ordered a set of the China stud kikit so hopefully they will be in this week.
Old 03-30-2017, 12:28 PM
  #202
BTR Platinum kit showed up today. Hopefully the head studs will be here tomorrow and thw motor can go in this weekend.
Old 04-01-2017, 01:10 AM
  #203
Motor is all together finally. Need to install the -10 weld bungs for turbo drains still. Hopefully truck will be here tomorrow and motor will be going in.
Old 04-18-2017, 08:54 PM
  #204
Decided to clean up the firewall, filled all the holes and got rid of all the factory wiring, wiper motor. Rewiring everything with a universal harness.
Motor is back in finally.
IAT sensor threaded into the purge solenoid opening.
Turbos are going back on with new wastegates.
Decided the compressor housings needed a little color. Not sure about them yet🤔
Got all of the wiring for the lights, fans, MS Gold Box done. Waiting on some parts to get more done.
Old 05-12-2017, 09:00 PM
  #205
Motor is in, all wiring is done and working.
New dash, column and steering wheel.
Old 05-12-2017, 09:01 PM
  #206
Old 06-01-2017, 08:10 PM
  #207
Default First drive with new setup!!!
Old 06-01-2017, 09:00 PM
  #208
RonSSNova's Avatar
Congrats! Fog em up man!
Old 06-02-2017, 09:50 AM
  #209
Thanks! Can't wait to get it ready for the 1/8!
Old 07-17-2017, 04:43 PM
  #210
Old 01-18-2018, 06:24 AM
  #211
So after 2 runs in the quarter, it would not start and found the number one rod bearing spun. Got a crank, GEN4 rods and pistons, machine work and installed everything again. The results have been satisfying to say the least.
Old 01-18-2018, 06:26 AM
  #212
Went down the track spinning cause of really bad tires so picked up a set of new slicks and the truck hooks really nice, then too good!!
Old 01-18-2018, 06:38 AM
  #213
The results of launching at 10lbs of boost instead of 4lbs!!
Bent the leaf springs, broke the slapper bars and driveshaft.
Out of the truck
Old 01-18-2018, 06:40 AM
  #214
New suspension
Fabricated a 4link
And picked up some cheap coil over kit
Old 01-18-2018, 11:45 AM
  #215
Bad Apache's Avatar
You may want to check the transmission. Usually hurts that as well when the driveshaft pukes. Nice launch though!
Old 01-18-2018, 11:59 AM
  #216
Pulled it and double checked everything!! Still has the Raybestos lettering on the clutches and bushings all look great!! It will be back out soon and looking forward to getting a full time slip! seems everytime it has a good run something goes wrong with the timing systems!!
Old 01-18-2018, 12:01 PM
  #217
Bad Apache's Avatar
Good deal! You're just finding the weak links!
Old 01-18-2018, 12:04 PM
  #218
OH YEAH!! forgot to add in the BTE transbrake is flawless!!! And I built a sheet metal intake one day when I was bored!!
Old 01-18-2018, 12:06 PM
  #219
Yes!! The weak link was listening to someone else who told me to remove the middle leaf. I should have looked into doing this and found that no one removes the middle leaf in a three stack setup!!!!
Old 01-18-2018, 02:56 PM
  #220
BudRacing's Avatar
Funny that you got lined up against a GLC300, haha! My wife has one. Honestly, it's a lot quicker than I expected a 2.0T to be in a small but still heavy SUV. The transmission does the platform a lot of favors. Any idea what it ran? I would guess 14's.
Quick Reply: Scrapyard S10
