Are the Corvette jack pads a good investment?
Thinking about various jacking and stand options and ran across something called Corvette Jack Pucks/Pads. Several "versions" all the way from fairly expensive pre-formed pucks to homemade from bolts and hockey pucks.
Anybody have any experience with these on the V1 and did you find them worth the investment?
Corvette Lifting Pucks
Last edited by WoodyFromBama; Sep 8, 2017 at 01:23 PM. Reason: To add picture reference...
If you have a good jack with a polyurethane saddle cover and you pick your jacking points correctly, the jack pads won't save you time or paint damage. I bought them hoping that I could leave them installed, but the places where they fit into the frame rails are prime for getting nailed by speed bumps.
If you have money to burn and want to decrease your set up time, buy four ESCO 10498 jack stands. They're lighter and more forgiving than Torin T40062A stands, and they won't leave marks on the ground.
https://m.harborfreight.com/rubber-pads-for-jack-stand-2-pc-63373.html?utm_referrer=direct%2Fnot%20provided
I've had poly pads for my jack stands for years, but never bother to use them.
Thanks all.
https://www.rockauto.com/en/moreinfo...=3261777&jsn=1
ÜRO PARTS 51711960752
$4.50 per pad when I got them months ago. Plug N Play in the rear and leave them in. Put the fronts in when I jack up the car.
Last edited by kra86; Sep 19, 2017 at 12:49 PM. Reason: added name and part number
Simple, cheap, effective. When I got mine years ago they came from the BMW parts counter... I got them for a C5 Z06. They don't stick out bad so I just left them plugged in all the time. I have a set in my V too. Can't got wrong with them.
***** https://www.moderngenauto.com/C5-C6-...et_p_2853.html *****
