OLD 10.5 mustang to no prep terror street car
Old 10-16-2017, 01:30 PM
  #61
LLave's Avatar
Awesome work. Your fab work looks really nice. Thanks for sharing.
Old 10-19-2017, 04:58 PM
  #62
MIAmotorsports's Avatar
Starting on the paint. Front bars will be silver everything else will be black.
The inside and firewall shoildl be done by next Wednesday
Old 10-22-2017, 07:21 PM
  #63
For those that wanted to know, the doors weigh 33.5lbs a piece. That weight includes mirrors, all the guys from a stock door, and all the trim around the door will edges etc
Old 10-24-2017, 02:12 PM
  #64
Paint is done on the front half, cage, interior, firewall and front strut towers. Wiring the efi, putting in motor and tranny is next along with installing turbo system. It is starting to look more like a car and less like a project. Almost forgot the Racecraft front k member and suspension along with the 17in v-series
Old 10-24-2017, 02:19 PM
  #65
svslow's Avatar
Not going to use a motor plate?
Old 10-24-2017, 03:13 PM
  #66
No 100% yet. It will be a no prep car so a little flex isn't a bad thing.
Old 10-24-2017, 03:34 PM
  #67
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,142 Likes on 742 Posts
Looking good.
Old 10-25-2017, 07:27 PM
  #68
Got the front back on and dash in. The black and silver look good together. I dyed the dash the factory black and it looks spot on. Even cut it so you could read the VIN.
Old 10-25-2017, 07:30 PM
  #69
Next up was gift wrapping it with tape so the paint doesnt get too messed up when the rngine and tranny is installed and all the wiring plumbing of the lines etc
Old 10-26-2017, 08:50 AM
  #70
LS1Tech Co-Founder
Looks good. I need to get one of his steering wheels, so light.
Old 10-26-2017, 07:24 PM
  #71
Call LJRC's theu will hook u up. It is perfect size and feels good when u grab it, Not to thin and it grips well with the texture
Old 10-27-2017, 12:49 PM
  #72
LS1Tech Co-Founder
Yeah I've talked to his guys (been there once when helping a buddy). Next year for sure!
What is your planned raceweight with the car?
Old 10-27-2017, 02:07 PM
  #73
AnotherWs6's Avatar
Holy fiberglass everything!
Old 10-28-2017, 12:49 PM
  #74
2500lb with 200lb srivwr
Old 10-28-2017, 01:06 PM
  #75
For sure. Wasn't going to do the front but I is so much easier to cool it down and work on it at the track. I went with H.O. doors because it is still a street car. I am putting sound deadener in it and good carpet so I had to loose weight somewhere. I almost didn't go with the fiberglass dash but there will be so much electronics in the car i went fiber glass too. The fast dash looked better sitting there with the fiberglass. The steering look3d like **** with the stock dash too.
Old 10-28-2017, 02:15 PM
  #76
rkupon1's Avatar
Cool build thread! Nice work so far!
Old 11-26-2017, 06:42 PM
  #77
Got ls2 with ARP everything. K1 rotating assembly with heavy duty wrist pins, wiseco 10.1 pistons, pinned mains, 1/2 filled. Figured I would start out aluminum since I as going with a aluminum Dart block after a season on the chassis.
Old 11-28-2017, 08:10 PM
  #78
Here is a better pic of the rear setup for those who asked. Nothing special just a typical 4 link
Old 01-08-2018, 06:10 PM
  #79
235lb injectors for e85
Billet atomizer 3 injectors
Old 01-08-2018, 06:14 PM
  #80
New beadlocks. I had some custom made because O wanted the tire to sit closer to the outside wheel well. They have a 5 3/8 backspace
Quick Reply: OLD 10.5 mustang to no prep terror street car
