Old 10-29-2017, 08:35 AM
  #721
Jimbo1367's Avatar
That looks amazing. !!!!!
Old 10-29-2017, 08:22 PM
  #722
franktf's Avatar
Thanks.....
Got everything all bolted in, brakes on and bled..... I have 1 little mod to do on the exhaust and I'll get the drive shaft shortened this week, then we should be ready to go again.....
Old 10-30-2017, 11:55 AM
  #723
aggie91's Avatar
Looks good. Did you ever figure out why the first gear set would not give you a good pattern?
Old 10-30-2017, 03:52 PM
  #724
franktf's Avatar
I have no idea, it looked like the pinion was to deep so I moved it out .005 and it got a little better..... The 4th time I moved it out .005 the pattern went off the reservation..... I was a Ford Racing Gear, I have never had a problem with one before but I guess there's always a first time.....
The one I set up this weekend was a US Gear, went in first shot no problems at all....
Old 11-05-2017, 06:53 PM
  #725
franktf's Avatar
Finally all back together..... Went through the gear break in cycle, drove it around some Sat and Sun to put it through a couple heat cycles..... Everything seems fine so I reset the cal-tracs and recheck the front end alignment..... I'll probably drive it a some the beginning of the week and get it back out to the track on Wed nite!!!!!
Old 11-05-2017, 07:58 PM
  #726
TipsyMcStagger's Avatar
I've been following along and I'm always impressed with your skills. I wish I were half the mechanic you are.
What's up with the Wed night track situation? I'm local and have never been to the track here. I'd be interested in coming by for a bit.
Tipsy
Old 11-06-2017, 04:07 AM
  #727
franktf's Avatar
Tipsy
Thanks!!!!! Wed nite tune-n-test at Showtime Dragstrip..... East on 126 Avenue off 49th street all the way to the end..... You can look up Showtime on the net.....
Old 11-06-2017, 07:19 AM
  #728
Okay...right near PIE. I'll try to swing by.
Tipsy
Old 11-11-2017, 12:39 PM
  #729
franktf's Avatar
Got it to the track Wed nite..... She leaft harder then ever right up to 1 sec into the pass when it had a catastrophic planetary failure..... It only had a rebuilt 1.76 planetary set, but I still find it hard to believe it gave up off the footbrake..... It leaft on 3.5lbs and was at 18.6lbs at 4 tenths into the hit, it was going to be a good run.....
Here is the carnage.....
Old 11-11-2017, 12:58 PM
  #730
Project GatTagO's Avatar
Brutal damage! I thought PGs were supposed to be pretty strong?
Andrew
Old 11-11-2017, 01:19 PM
  #731
Old School Heavy
speedtigger's Avatar
Andrew
They are. Once you have 3 -4 grand in one.
Sorry about your luck out there Frank. I have killed a few planetaries myself. Not a good sound.
Old 11-11-2017, 04:04 PM
  #732
franktf's Avatar
Andrew
HA HA!!!!!
I must be gettin close to a good one now, with the new planetary set I'll be in for around $3500 and I do all the labor.....
Old 11-12-2017, 07:22 PM
  #733
franktf's Avatar
I got everything all cleaned up and ready to reassemble, I put as much together as I could..... Parts are ordered.....
Old 11-16-2017, 10:35 AM
  #734
aggie91's Avatar
Dang...
Well, like I have heard before with cars we like: Build, Brake, Repair, Repeat!
Old 11-17-2017, 08:30 AM
  #735
408GT's Avatar
That sucks Frank. Just one thing after another!
Old 11-17-2017, 06:51 PM
  #736
franktf's Avatar
Dang...
HAHA!!!!!
Ya play with fast cars and ya get a lot of broken ****..... Just how it goes.....
Got the trans parts this week..... The trans is all back together and ready to go back in tomorrow morning.....
Here's the new FTI 1.80 straight cut planetary set I got for it, and then the trans back together.....
Old 11-18-2017, 11:42 AM
  #737
franktf's Avatar
Back together and running again, hopefully for a while this time.....
Old 11-18-2017, 06:38 PM
  #738
Motown 454's Avatar
Sorry to hear about the trans, good luck with this one. Will the change to the 1.80 make any difference in your times?
Old 11-19-2017, 02:17 PM
  #739
franktf's Avatar
From a 1.76 to 1.80 shouldn't make much difference..... Unfortunately I will never know, because it broke on the first pass at this boost level and the tune is still super soft.....
Old 11-19-2017, 02:34 PM
  #740
JayinMI's Avatar
Do you mean it broke on the first pass last time, so you don't have a comparison, or that the just completed rebuild broke on the first pass?
Jay
