Shark Gray 2000 SS build
Scored a set of Fikse FM5's wheels from a fellow Louisiana ls1tech member, they just needed to be refinished.
Test fitting the rears.
Stripping the clear coat.
Wet sanding, removing the machine finish.
All polished up.
315/35/17 Nitto 555Rs
While dyno tuning the car, we noticed that it was passing oil on decel. After researching I found that I forgot to seal my rocker arm bolts since these heads are ported. Easy fix.
First time auto crossing in general, it was a blast. Car handled very well, even on drag radials.
Put it on the scale after doing the front bumper support, rear seat, and radio delete.
Unfortunately had a full tank of gas. Not bad for a T-top car.
I drove it for a few months without the front grille just to change up the look.
Car is on Koni Yellows and Vogland springs. I removed the rear isolators and SS bumpstop spacers. Had to roll the rear fender lips.
Entered it into the local Pepboy's dyno challenge and won highest horsepower NA.
Car put down 438/380 on this dyno, IATs were in the upper 90s.
Added a 67 SS emblem to the grille. Also stripped the black side marker and tail lights for a cleaner look.
Looks a lot better without the rake.
Local car meet with fellow LS1tech member.
Back at the track chasing an 11 sec run.
The Speed Engineering Dual exhaust kit was being pushed into my fuel tank by the rear axle. It was also loud and droned at HWY speeds. I pulled off the piping after the x-pipe and sold it. Then I bought (2) Magnaflow 5" mufflers and had the exhaust show weld them in.
Good clearance.
Spun a rod bearing in the burnout box.
Ran a 12.09 @ 120 on the previous run.
Back at home, beginning the tear down, took me about 2 weeks before I had the interest in tearing it apart.
Dropped it from the bottom with a 1.5 ton jack.
Heads and rockers look great.
Old exhaust setup.
Oil leak from the cam sensor made a nasty mess.
Monster stage II clutch.
