Shark Gray 2000 SS build
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170510_202403_4b34a330e7044046167e3956e8dadb2406d687ae.jpg)
Scored a set of Fikse FM5's wheels from a fellow Louisiana ls1tech member, they just needed to be refinished.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170510_202650_4a9fc612f9a3102abefc0129949cab13ead9ad76.jpg)
Test fitting the rears.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170511_173555_8b7b847b8bc28d333d5cd7b9aba278928ed7d604.jpg)
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170511_173616_76ae0f8698b4552a9fc102e3f40c4faebfa501f7.jpg)
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170512_182917_3e3d404dadd83b7d17a7cce34c0f5c080dbefa46.jpg)
Stripping the clear coat.
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170512_182929_36ecb1fb33f2ea01bd60e9459484695bf696ef0d.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170515_104728_ddac2100af583af685c55117aea1480ac40c20db.jpg)
Wet sanding, removing the machine finish.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170515_104735_d39c131bff20c31fbecc928c8937bb75d2796df1.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170515_110652_d001bd463bc628c6d598aa3b9b977c52403d8788.jpg)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170515_121259_43c7f3e4519967f310e54e39a7bd84d66c0042e8.jpg)
All polished up.
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170515_121317_c14f256c476ee1c253f49cc86e0a38022006447e.jpg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170515_121836_4c14036ca18d16575b4fea6d726fb4e6e0deb16d.jpg)
315/35/17 Nitto 555Rs
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170515_122409_74da3b633b860787ee0fbd75f08ac5021412656c.jpg)
Jessemess (11-10-2020)
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170607_200500_862eb513f70a18834aeb09aa0cbc79acb38e89bb.jpg)
While dyno tuning the car, we noticed that it was passing oil on decel. After researching I found that I forgot to seal my rocker arm bolts since these heads are ported. Easy fix.
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/720x480/fb_img_1497927968010_dc65dbf1dc37b99df0492ef6c88d2bd61742f091.jpg)
First time auto crossing in general, it was a blast. Car handled very well, even on drag radials.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/720x480/fb_img_1497928243301_a6bae2a23e80b545df91f0a5fd0d7d31f2ab721e.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170618_100233_35e7cd5e84ec0778f25aaca2c5b963b061e43874.jpg)
Your welcome, What headlights are those? Do you like them?
Mine are foggy & need replaced.....
Edit.....I think I'll start a thread on my car, Thanks for the inspiration!
LaBLKv6Z (05-24-2023)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170513_154327_5dfd0c235401cdb302b74244e368a7da31178517.jpg)
Put it on the scale after doing the front bumper support, rear seat, and radio delete.
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20170513_154352_4c0de8db68171a48ecb9444815c3d591e74ced0b.jpg)
Unfortunately had a full tank of gas. Not bad for a T-top car.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170513_154408_23279836c760cb64d0262560120bcd9c2c873749.jpg)
I drove it for a few months without the front grille just to change up the look.
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170513_154425_88906e0d1fb5f5dc729681ce912e8def1a1107fe.jpg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170513_154452_a9060fec0443b4d12dab8f124a0d8b9405a6bc84.jpg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170925_192959_f408f819b0f1b6a0df238aa648fbbaad35b4bdfd.jpg)
Car is on Koni Yellows and Vogland springs. I removed the rear isolators and SS bumpstop spacers. Had to roll the rear fender lips.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170805_100304_b54d2869846285e35e71af5bb94e853d0f4d1fd7.jpg)
Entered it into the local Pepboy's dyno challenge and won highest horsepower NA.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180128_153211_130de3fbf26abf52524e0ba118d99e0ba16c7198.jpg)
Car put down 438/380 on this dyno, IATs were in the upper 90s.
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171008_170134_7efcc1be83626af4281c506bb050ff746ede0b99.jpg)
Added a 67 SS emblem to the grille. Also stripped the black side marker and tail lights for a cleaner look.
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171008_170243_d860655a262beb6accf7002954f45055da835a23.jpg)
Looks a lot better without the rake.
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171015_160202_ef6c0bd495e194685721d15e0e0ecb04bdb42ac0.jpg)
Local car meet with fellow LS1tech member.
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171029_105426_1d8ead69ee9beded735fe1c7948e0e068a7244dd.jpg)
Back at the track chasing an 11 sec run.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171029_124504_dc0d4cd92ed9dbb2fc5e7fea195e1bb162589f02.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171029_144926_cb4c4aadbdc30f8d8678f03517e13c599f6ef6b3.jpg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_091149_7076a44c060dcf06d103e9359b425d7d84c61871.jpg)
The Speed Engineering Dual exhaust kit was being pushed into my fuel tank by the rear axle. It was also loud and droned at HWY speeds. I pulled off the piping after the x-pipe and sold it. Then I bought (2) Magnaflow 5" mufflers and had the exhaust show weld them in.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_091208_c53604dbb4c17a9eed6bec0610096ca687d2322d.jpg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_105003_b46a0ce3c28b3d605ea185167846db63f7e62e56.jpg)
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_111453_b03722a1cce0c4f2e92863cc300856a9284d4622.jpg)
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_111519_2cae77f661ae4ffe76654bbdd1ed591068d08a27.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_135716_fb9b3b8218c1c8a33bdca14765599ac333b88e33.jpg)
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_135729_63e3047a08a998401f3c5c0294813249bb481561.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170701_135748_8176c6611ad23e14a52fc7fff83608d49b75247b.jpg)
Good clearance.
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20170805_065712_6812332f1f0a78410d9297c28ca35ff3068b1f8e.jpg)
*Just an update guys, last week of Dec 17 I spun piston rod bearing #3 while doing a burnout at the drag strip. Since then I've dropped the engine out of the car and completely disassembled the block. I parted out and sold pretty much the complete engine.
#39
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171210_151718_a123f79e0054a58589693da73824e6c1521f847d.jpg)
Spun a rod bearing in the burnout box.
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171210_153351_accf96e363521e9f1aca496eb3c82131478d83f8.jpg)
Ran a 12.09 @ 120 on the previous run.
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171210_153556_5378fa7d9935f5986898687ec1af92b39742714c.jpg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171213_195922_78f2960341a045de3a85a6b034c9e04dda713da8.jpg)
Back at home, beginning the tear down, took me about 2 weeks before I had the interest in tearing it apart.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20171213_195945_f22b9899878a7ec5ba6aa099ae04eef9d8d73b76.jpg)
#40
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180101_174031_7c562e158c4f984c42bf0fa84cc2b4032d04a927.jpg)
Dropped it from the bottom with a 1.5 ton jack.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180101_174042_c3da8065b5130ff50843ae17bf51e705a3925b7b.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180101_174102_3445367e857b031fe5d0396c7eaaa6ac8fad3509.jpg)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180102_201235_1d6f9cffbd4de18ad36ba6181d6864e7cae5ef0e.jpg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180102_201252_e2978522ff1525ba183889c060f457473b5b1441.jpg)
Heads and rockers look great.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180102_210846_8637df4eef2d1df247540de82b0afc73e415cdbf.jpg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180102_210922_57794215897b2b10539991667dfdd54b099dce07.jpg)
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_20180102_210933_54a5988e01ed4cff768bf0736fa1f9f506474fd5.jpg)
Old exhaust setup.
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180102_213037_96d9735581458126859e6d55fcf48b07c1b48c81.jpg)
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180103_191259_22b706b5e8a2400f1f8a6902bfea1c86747484ca.jpg)
Oil leak from the cam sensor made a nasty mess.
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180103_191325_00afec1c9f521543a2f16edd0037b6879cca16d6.jpg)
Monster stage II clutch.
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/img_20180103_194317_b600a2d9df4b2edc6fae9550a12cdab299cdcb72.jpg)
