LS NEXT II 427" Build For F1a94 ProCharger
Here is the breakdown:
- Dart LS NEXT II Full Skirt Alumunum Block with 1/2" main and head stud upgrade - 31947211
- Callies Dragon Slayer Crankshaft -APO31T-DS with 58x billet reluctor
- Carrillo Forged I Beam "1500 HP" forced induction connecting rods - BCLSX612571
- Diamond's new 2000 HP Forced Induction Pistons with tool steel wrist pins -21544
- Total Seal Steel top ring piston ring set
- GM Performance 6-Bolt Head Gasket - 19170419 or maybe Cometic MLX
- Dart Pro 1 LS3 cylinder heads CNC ported by Frankenstein Engineering Dynamics - 11030050(bare head part #)
- Edelbrock Super Victor Intake ported by Frankenstein Engineering Dynamics
- T&D Shaft Mounted Aluminum Roller Rocker Set - 20044
- Cam Motion 8620 LLR Low Lash Solid Roller Camshaft 247/261 on 116.5+4.5 with .689"/.672 Gross Valve Lift - 03-08-0000 LL247/405-LL261/395-16.5+4.5
- Cam Motion Premium Solid Roller Lifters with Axle Oiling & .750" wheel - LS034122201
- Cam Motion 3/8" Diameter, .135" Wall 7.550" long Pushrods - PS17550201
- Cam Motion LS Premium .750" Street/Strip Double Spring Kit With Titanium Retainers - VSK143306
- ProCharger F1a94 with Cog-Drive 71 Crank and 40 Tooth Blower Pulley (72,000 RPM @ 7500 engine RPM)
- CSU 850 CFM e85 Blow Through Carburetor with 4 needle and seat bowls
The stuff has started coming in, so pics are next.
ProCharger sent a nice hat with the kit, but I think it is a bit small for me.
ARH 2"x3 1/2" stainless headers
Circle D 245 mm 2c torque converter
Extreme Automatics 4L80 with billet everything including billet manual valve body with brake.
Aeromotive 4 port regulator and Aeromotive Eliminator fuel pump.
Some more bars on the cage to make it 8.50 ET legal
They were never flowed. I don't know if Frankenstein has flow numbers for this head program or not, I would have to ask.
Here are some pix before the 6-point and the Welds:
The CSU 850 CFM 4 needle and seat blow through e85 carb.
