LS NEXT II 427" Build For F1a94 ProCharger
Old 02-10-2018, 10:12 AM
Old School Heavy
speedtigger's Avatar
Default LS NEXT II 427" Build For F1a94 ProCharger
This year I am transitioning from nitrous to ProCharger. So, I sold my old 403" LS2 short-block and I am building an LS NEXT II, aluminum full-skirt block based 427" short-block for forced induction.
Here is the breakdown:
  • Dart LS NEXT II Full Skirt Alumunum Block with 1/2" main and head stud upgrade - 31947211
  • Callies Dragon Slayer Crankshaft -APO31T-DS with 58x billet reluctor
  • Carrillo Forged I Beam "1500 HP" forced induction connecting rods - BCLSX612571
  • Diamond's new 2000 HP Forced Induction Pistons with tool steel wrist pins -21544
  • Total Seal Steel top ring piston ring set
  • GM Performance 6-Bolt Head Gasket - 19170419 or maybe Cometic MLX
  • Dart Pro 1 LS3 cylinder heads CNC ported by Frankenstein Engineering Dynamics - 11030050(bare head part #)
  • Edelbrock Super Victor Intake ported by Frankenstein Engineering Dynamics
  • T&D Shaft Mounted Aluminum Roller Rocker Set - 20044
  • Cam Motion 8620 LLR Low Lash Solid Roller Camshaft 247/261 on 116.5+4.5 with .689"/.672 Gross Valve Lift - 03-08-0000 LL247/405-LL261/395-16.5+4.5
  • Cam Motion Premium Solid Roller Lifters with Axle Oiling & .750" wheel - LS034122201
  • Cam Motion 3/8" Diameter, .135" Wall 7.550" long Pushrods - PS17550201
  • Cam Motion LS Premium .750" Street/Strip Double Spring Kit With Titanium Retainers - VSK143306
  • ProCharger F1a94 with Cog-Drive 71 Crank and 40 Tooth Blower Pulley (72,000 RPM @ 7500 engine RPM)
  • CSU 850 CFM e85 Blow Through Carburetor with 4 needle and seat bowls
The stuff has started coming in, so pics are next.
Old 02-10-2018, 10:14 AM
Old School Heavy
Here is a picture of the car it is going in:
Old 02-10-2018, 10:19 AM
Received 3,121 Likes on 2,434 Posts
Nice launch!!
Old 02-10-2018, 10:21 AM
Old School Heavy
The block and crank:
Old 02-10-2018, 10:26 AM
A.R. Shale Targa's Avatar
Somebody get me a towel.....just messed myself....
Should be a total monster....look forward to the build process..
Old School Heavy
Piston and Rods:
Old 02-10-2018, 10:33 AM
Old School Heavy
The ProCharger and matching camshaft:
ProCharger sent a nice hat with the kit, but I think it is a bit small for me.
Old 02-10-2018, 10:34 AM
sxc Z28's Avatar
sub'd
Old 02-10-2018, 10:48 AM
Old School Heavy
The heads arriving. I have already run these on my old nitrous setup, so more pics to come when they are cleaned up again. The Dart Pro1 LS3 heads are excellent to start with, but even these great heads picked up nearly 3 MPH in the 1/8 mile when Frankenstein reworked them. Amazing.
Old 02-10-2018, 10:49 AM
Another towel please. LMFAO
first post says 261 Ex lobe; box shows 256 on the end ??
Old 02-10-2018, 10:57 AM
Old School Heavy
Good catch. It looks like I screwed that one up when I had it ground I guess I will have to regrind that exhaust lobe.
Old 02-10-2018, 10:59 AM
Old School Heavy
Here is the part that triggers the EFI tuners The CSU 850 CFM 4 needle and seat blow through e85 carb.
Old 02-10-2018, 11:08 AM
Old School Heavy
Other supporting items coming soon are:
ARH 2"x3 1/2" stainless headers
Circle D 245 mm 2c torque converter
Extreme Automatics 4L80 with billet everything including billet manual valve body with brake.
Aeromotive 4 port regulator and Aeromotive Eliminator fuel pump.
Some more bars on the cage to make it 8.50 ET legal
Old 02-10-2018, 01:21 PM
Ummmmmm yeah; might be a problem when this thing runs twenties.
Love the CSU blo thru stuff. Flat out works !!!!!!
Old 02-10-2018, 01:32 PM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Steve,
Congrats on the new combo, way to step up!
Looking forward to results.
Will you be able to post Flow#s on your Heads?
Old 02-12-2018, 02:44 PM
Old School Heavy
Yeah, if it tries to go that fast, I will turn it down. I don't want to go that fast in this chassis. That is one of the reasons it has the F1a94 and not the F1x.
Originally Posted by NAVYBLUE210
Steve,
They were never flowed. I don't know if Frankenstein has flow numbers for this head program or not, I would have to ask.
Old 02-12-2018, 02:51 PM
AnotherWs6's Avatar
Rock hard over the blow through, though I have yet to achieve completion like A.R. did.
Do you drive this thing on the street still?
Old 02-12-2018, 03:33 PM
Old School Heavy
Absolutely! It is primarily a street car. If I were to have a racecar, I would use something light! LOL. When it is on the road, I drive it about 2-3 times a week. I love driving it. It has overdrive, full interior with factory console and seats, power steering etc.
Here are some pix before the 6-point and the Welds:
Old 02-12-2018, 04:05 PM
AnotherWs6's Avatar
That thing is going to be fuuuuuuuuuuun.
Old 02-12-2018, 05:10 PM
That is one CLEAN Buick! Lookin' GOOD!
Quick Reply: LS NEXT II 427" Build For F1a94 ProCharger
