Shark Gray 2000 SS build
Old 03-06-2018, 12:31 PM
  #41
LaBLKv6Z's Avatar
Heads still look great also.
Ended up selling the PRC 2.5's, very happy with them.
Old setup also sold to various members on here.
Old 03-06-2018, 12:34 PM
  #42
LaBLKv6Z's Avatar
Here's the damage, #3 rod bearing spun and started to take out #4. Not too bad, crank is probably salvageable. Sold the shortblock to a guy putting it in his 67 blazer.
Old 03-06-2018, 12:46 PM
  #43
LaBLKv6Z's Avatar
So on with the plans.
I purchased a built 383 from 11secLS1 on here.
I bought a UMI k member along with their lower control arms. I blasted and painted the spindles and oem replacement upper control arms.
I'm currently cleaning the firewall and frame horns, going to paint that gloss black along with the under carriage and fender wells.
Ordered some stainless brake lines and will be repainting my calipers.
I twisted the splines in my Strange cast yoke so I replaced with their chromoly version.
On the interior, I am installing a Sparco steering wheel and replacing the dash pad (current one has a small crack).
Old 03-09-2018, 10:13 PM
  #44
LaBLKv6Z's Avatar
Installed my Sparco steering wheel. Used the MOMO hub. Had to shave a little plastic out of the column, yes horn still works.
Been working on my buds 99 z28. Cam/bolt on M6. Had the RS ground effects.
Helped him do some weight reduction.
F-body life.
Old 03-22-2018, 07:05 AM
  #45
LaBLKv6Z's Avatar
More parts came in.
Going to try to fit these behind my Fikse FM5s.
Old 03-22-2018, 07:45 AM
  #46
Toes's Avatar
Your buddies RS I see you removed the ground effects. How much weight you think it was? An how was body under it?
Old 03-22-2018, 11:23 AM
  #47
LaBLKv6Z's Avatar
The RS kit might have weighed 15 lbs max. The paint was ok under the kit but multiple holes were left behind from the rivets. It still looks way better without the kit.
Old 03-22-2018, 09:13 PM
  #48
CoreyD's Avatar
Those brakes!!
Old 03-24-2018, 12:21 PM
  #49
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
Sweet car, love the color and how it's tastefully done.
Old 03-26-2018, 08:51 AM
  #50
LaBLKv6Z's Avatar
Originally Posted by CoreyD
Those brakes!!
Yeah bud going to try and make them fit behind the Fikses.
Thanks man.
Engine has arrived, it’s a 383 LS1 with a bunch of goodies. Picked it up for a great price from a fellow member.
Old 03-30-2018, 08:48 PM
  #51
LaBLKv6Z's Avatar
Pulled the hoist out to put the engine on my stand.
Frankenstein Engine Dynamics 243 heads.
Old 03-31-2018, 04:34 PM
  #52
LE35TH's Avatar
This thing is going to be a monster! Can't wait to see it roaming the streets!
Old 04-01-2018, 08:21 PM
  #53
LaBLKv6Z's Avatar
Haha I wouldn’t call it a monster but it should be fun again.
Old 04-01-2018, 08:42 PM
  #54
LaBLKv6Z's Avatar
Got the firewall and frame horns painted.
Installed the rest of the accessories. Steering rack bolted right up to the UMI k-member.
Original T56 cleaned up.
Old 04-07-2018, 09:53 AM
  #55
LaBLKv6Z's Avatar
So turns out the TSP 2" headers will need to be clearanced at the steering shaft and a little between the passenger side frame. Not to bad considering the size of these tubes.
The UMI k-member bolts right up to the subframe and looks great. I am going to replace a couple of seals on my steering rack before I torque everything down. Can't stand leaks.
Still need to locate a 14mm drill bit to drill my caliper bolt mounting holes out (spindle) to fit the larger bolts required for the Brembos.
Old 04-07-2018, 10:56 AM
  #56
FinalCam's Avatar
This is a sick build! Super clean car. I love the attention to detail, keep up the great work
Old 04-07-2018, 02:52 PM
  #57
LaBLKv6Z's Avatar
Off of the stand and onto blocks to install the flywheel, clutch, trans.
Clutch installed.
Finally time to roll it in.
Old 04-07-2018, 02:55 PM
  #58
LaBLKv6Z's Avatar
Thanks man, been nipping away at it afterhours.
Old 04-09-2018, 08:42 PM
  #59
CoreyD's Avatar
So close!!
Old 04-10-2018, 05:58 AM
  #60
LaBLKv6Z's Avatar
Pulled the pwr str shaft seal out, just waiting on a new one to be delivered.
Headers are now clearing the steering shaft and subframe.
C7 front discs
Quick Reply: Shark Gray 2000 SS build
