4th Gen Camaro Street Car New PB 7.81@177
Old 04-03-2018, 11:20 AM
  #81
BlackSS4thgen's Avatar
Old 04-05-2018, 04:03 PM
  #82
busa3268's Avatar
Coming along Great !!
Old 04-06-2018, 12:06 AM
  #83
Old 04-06-2018, 06:07 AM
  #84
svslow's Avatar
What happened with the Holley intake?
Old 04-06-2018, 05:59 PM
  #85
I weighed the two and decided for being the same weight Id run the pro flo for a while. It is better constructed and it fits in my hood. I didnt seem to notice any difference in the two as far as rpm limit. The difference was a half of mph and the car was 30lbs lighter when it picked up the half mph with the holley. Also launched better and wasnt spinning. So its a toss up. Ill probably throw one on mid season and see what it does.
Old 04-06-2018, 06:02 PM
  #86
Old 04-06-2018, 06:30 PM
  #87
stevieturbo's Avatar
Visually the Holley intake looks nicer...although having seen the quality of mine, I've no doubt the Edelbrock will be much superior quality.
Old 04-06-2018, 06:52 PM
  #88
I absolutely hate how the fittings are BPT and on the bottom of the intake. I was going to tap a fitting on the rear to run a vacuum block.
Otherwise it didnt matter to me either way. I guess end of the day the pro flo has longer runners and I want to see if I can get anymore rpm out of it with the 3/8 pushrods. Even 100-200 more rpm would be great. Mid season Ill put a cam in that is made for this combo.
Old 04-09-2018, 02:16 AM
  #89
bboyxclub's Avatar
This thing is awesome man!
What kind of oil pump are u using to keep the engine happy at that high rpm?
Thanks
Old 04-09-2018, 10:48 AM
  #90
Thanks
On the old iron engine I used an oem high volume pump 12678151.
With the aluminum block I bought a Melling M295HV. It seems to hold 5 more psi at cold warm idle with the same bearing clearances.
Old 04-12-2018, 10:32 AM
  #91
Finally did some weight reduction in the rear to make up for the front weight loss.
Old 04-12-2018, 12:10 PM
  #92
svslow's Avatar
What kind of carpet is that? Did you have to glue it down?
Old 04-12-2018, 10:23 PM
  #93
Ozite. Yes I used spray glue.
Old 04-12-2018, 10:35 PM
  #94
First time ever owning a Kirkey lol
Old 04-12-2018, 10:57 PM
  #95
MY_2K_Z's Avatar
Damn that's some serious weight reduction
Old 04-13-2018, 10:23 PM
  #96
Should be about 220 lighter. Im stoked for the summer!
Old 04-14-2018, 10:18 PM
  #97
Old 04-14-2018, 10:19 PM
  #98
Old 04-19-2018, 11:33 PM
  #99
Just for a freshen up. I bought all new fuel lines. Found a deal on some goodrich ptfe.
New pair of aem's with a straight 6oring-8an. No more check valves. Now we can see where these pumps completely run out.
I added a few pictures since people always ask me how the pumps are situated. twin 10an from tank to pump. 8an from each pump to the rear of each fuel rail.
Quick Reply: 4th Gen Camaro Street Car New PB 7.81@177
