Which T56 fluid?
My '00 S10 is factory filled with Snychromesh and I changed it at 25k with GM Snychromesh.No differences.Just fresh fluid/maintenance.I then again changed it at 125k but didn't want to pay some ridiculous $20/quart so I switched to the Amsoil as it was new to the market and only $7/quart.After 15k miles nowI can honestly say it is more objectional to shift in the cold (mornings/NY weather here) than the GM Snychromesh was.Once warmed up it does shift easier and does feel a little better/smoother.I myself will leave it in as I go easy on it till it warms up fully,but if you tend to shift a lil rough in the first few minutes of cold driving you will get better/easier shifts with the GM stuff.
Per my transmission rebuilder, who's rebuilt T56s for numerous hi-perf shops in my area, don't use Dex III. Only use Synchromesh or similar (either RP Synchromax or Amsoil Synchromesh). The Dex III is recommended by GM because it will lubricate the tranny internals better than the alternatives when cold, preventing unecessary wear from morons who don't warm it up before beating on it. But the Synchromesh will take care of everything MUCH better when warm, which is where 80%+ of your shifting is done (especially if you care about your car enough to join and post on a forum like this).
I've also heard good things about GM Synchromesh, I definitely wouldn't put regular old ATF in it though, especially if you run the car hard. Its worth the extra few bucks for the best protection for your rather expensive T56
Looking at the spec's, that seems to be a pretty kick 8ss lube...thicker when cold than ATF, but still, it should be pretty awesome just looking at the specs.
Even if the result is bad...can you still post back here? I'm just really curious to see how that stuff works...your the first I've seen post on using a SF lube in a F-body T-56.
Thanks!
Chuck
Thanks!
Chuck
BITOG is where I heard about this, and for the price, it really can't hurt to try. I was looking for Pennzoil Synchromesh, but since I didn't find any local, I just figured what the hell. Might as well give this a shot.
I almost can't wait for my FX4 Level II to get out of warranty...soon as it does, I'm ordering up some of MolaKule's stuff for my diffs and transfer case.
Chuck
