View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
Old Mar 2, 2006 | 12:46 AM
  #141
Red_Dragon's Avatar
I don't think I saw a post about this but if you have a 98-00 trans that has not been rebuilt with carbon fiber blocker rings you should not use synthetic. There is a good write up on LS2.com here is the link. I have a 98 I rebuilt my trans because my blocker rings were shot I use synchromesh in it now. hope this helps
Old Mar 2, 2006 | 01:54 PM
  #142
chucky2's Avatar
Red_Dragon- The guys over at LS1 (same as LS2).com and I had gone around on this before.
I'd created a thread over at LS1.com that had the same thread title and initial post as the one here, linked below:
Ending the speculation: Blocker rings, who's had them fail?
Unfortunately, the LS1.com forum went down or something, because that thread isn't available anymore....too bad, because there was good debate there on the subject.
What is clear is that there are many folks that have posted here that have been running synthetic in their non-rebuilt 98-00 F-body T-56's and have had, at worst, no change compared to dino Dex III, and at best, good improvent over dino Dex III. The fact that many of them have been running the synthetic for many 1000's of miles, and drive their cars both easy and hard, sometimes is lost on the Synthetic is bad for your T-56 crowd.
I'll freely admit however that other have put the same fluid others have used successfully (in 98-00 F-body T-56's), in their own 98-00 F-body T-56's, and have had bad results.
It seems to be a dice roll on whether or not synthetic fluid will work well or not in T-56's...I'd say most have an experience that ranges from "No change over dino Dex III" to "Yeah, that sh*t kicks 8ss!"...however, some have negative results.
In the end, it's just like any other mod to your car...it should be OK, and you hope it's going to do something positive...but, there's always the chance that something negative will happen.
Chuck
Old Mar 2, 2006 | 03:57 PM
  #143
SScam68's Avatar
I rebuilt my T-56.
I used Mobil1 syn. and then swapped to Valvoline dex III (the cheap stuff). The shifts got notchier and the gears started to grind. When the tranny was cold it shifted like total ****. Went back to Mobil 1 syn and everything is normal again. Smooth engagment and doesn't react to the cold.
.02
Might try GM stuff next just to see what difference it makes.
Old Mar 3, 2006 | 06:38 PM
  #144
Honda Nick's Avatar
I just put in the GM Syncromesh and I must say that it is superior to dexron 3 in every way. Everything is better in all temperatures.
Old Mar 27, 2006 | 01:40 AM
  #145
BriancWS6's Avatar
I went with Pennzoil Synchromesh with my freshly upgraded T56 and I love it! Even in the colder weather I have NO complaints with it. Been running it for about 2 weeks now.
Old Apr 3, 2006 | 08:55 PM
  #146
nomadnate's Avatar
Originally Posted by demonspeed
Always used Synchromesh in Tremecs.
totally true i asked some of the techs at work today that used to work and pontiac but i would go with royal purple i have seen impressive things from them
Old Apr 12, 2006 | 11:28 AM
  #147
NastySSoo's Avatar
I think its hard to use peoples experiences because a lot of t56 problems are caused by the drivers ability(or lack thereof). A bad driver tears up his tranny then says such and such fluid is no good. Ive always used the GM dex III in my untouched oo t56 and have had zero problems.
Old Apr 12, 2006 | 11:51 AM
  #148
black_z's Avatar
I am going to give honda ATF a try.
Old Apr 13, 2006 | 02:04 PM
  #149
BIG BAD BLACKSS's Avatar
Originally Posted by black00TA
yeah, for those of us who are still running on pre '01 transmisions...
we are all very much aware for this thank you.
K im the newbie and have a 99 T56, what am i missing out on? I know the shifter forks are aluminum instead of steel in the older T56, is taht what your reffering to orrrrr???? i hate being the newbie so much to learn!
Old Apr 13, 2006 | 03:13 PM
  #150
chucky2's Avatar
BIG BAD BLACKSS- The 98-00 F-body T-56's used paper/fiber/whatever you want to call it blockers, instead of the carbon ones used in 01+ F-body T-56's.
For those the make the argument that synthetic and/or non-Dexron III rated fluid is bad for 98-00 T-56's, this is the main reason...hence the thread I linked to in my reply to Red_Dragon.
Chuck
Old May 2, 2006 | 07:56 AM
  #151
MeentSS02's Avatar
Kleeborp the Moderator™
For all you wondering about the Specialty Formulations Synchroglide, so far, I've had great luck with it. Cold shifts are much smoother than when I had the dino Dex III in there, and warm shifts are a little better too (although it shifted smooth before under the same conditions). Rowing through the gears is no problem either...no grinding on high RPM shifts at all. I also used to have a fair amount of gear noise from the tranny in 1st gear, and that has been quieted considerably.
Questions? Let me know...
Old May 2, 2006 | 09:52 AM
  #152
NOIR's Avatar
I use gm synchromesh. didnt notice any real difference... not sure what that says. but im also having clutch isses. lol
Old May 2, 2006 | 10:38 AM
  #153
MeentSS02's Avatar
Yeah...clutch issues would kinda negate the effectiveness of a fluid...
Old May 2, 2006 | 07:59 PM
  #154
bad6as's Avatar
i have amsoil atf as stated, but im switching to amsoil's syncromesh
Old May 2, 2006 | 08:40 PM
  #155
Domestic Demon's Avatar
Originally Posted by Tobynine9
Don't know if I've given my .02 yet.
Per my transmission rebuilder, who's rebuilt T56s for numerous hi-perf shops in my area, don't use Dex III. Only use Synchromesh or similar (either RP Synchromax or Amsoil Synchromesh). The Dex III is recommended by GM because it will lubricate the tranny internals better than the alternatives when cold, preventing unecessary wear from morons who don't warm it up before beating on it. But the Synchromesh will take care of everything MUCH better when warm, which is where 80%+ of your shifting is done (especially if you care about your car enough to join and post on a forum like this).
Hence the reason I think I'm going to try and use Mobil 1 ATF in my trans. It provides the best lubrication when the trans is cold, yet being synthetic, it should protect the gears just as well even when it gets warm. Regular Dex III ATF probably thins out and loses some of its lubricating properties when it starts to get hot, Mobil 1 Synthetic ATF should be better in that regard since its fully synthetic.
Old May 3, 2006 | 01:24 PM
  #156
dailydriver's Avatar
Make sure you get back here to post the results once you have the Amsoil in for a few weeks. Many want to know how it performs in a T56. Thanks.
Old May 3, 2006 | 09:04 PM
  #157
SladeX's Avatar
Been running mobil 1 for almost a month now, I had an issue prior to switchng of 2nd gear grinding at 4k rpm or WOT runs.
I'd like to report that I haven't had a grind since switching. I flushed out the old transmission fluid first with some cheap dexron III and a about a day's worth of driving. Came out looking like a pearl paint.
Old May 4, 2006 | 11:19 AM
  #158
Deeavi's Avatar
I have done alot of research on engine oils and ATF. Mobil1 and Amsoil fully synthetics are the best!
Old May 7, 2006 | 09:13 PM
  #159
speed_demon24's Avatar
Where are you guys getting your penzoil syncromesh at? I can't find it down here.
Old May 9, 2006 | 12:06 PM
  #160
LPTXZ28's Avatar
Got my penzoil synchromesh at NAPA autoparts.
