View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
Old May 22, 2016 | 07:24 PM
  #301
blackandgold's Avatar
Swapped to pennzoil synchromesh (same as GM AFAIK) this morning and I'm happy so far. Info on my trans:
fully rebuilt with lots of new hard parts ~1 year ago, upgraded to carbon blockers and put in Mobil 1 synthetic ATF, swapped for fresh mobil 1 again 500 miles after the rebuild. The trans felt notchy almost a metal on metal feeling from the **** with lots of noise in neutral at idle.
I assumed most of my problems were due to the cruddy korean input shaft I dropped in. After the pennzoil the trans is quieter and shifts feel much easier without the odd feel. If it goes back to feeling crappy I'll try Dex 3 next. But I'm very happy with the pennzoil so far.
Old May 23, 2016 | 12:45 AM
  #302
bigsticksupra's Avatar
Mobil 1 synthetic ATF was the best i used. it stopped my 5th gear grind when cold.
tried synchromesh, RP synchromax, regular Dex III, and Redline
