Which T56 fluid?
Amber, Joe???
I decided to dump the Syncromesh and put in Mobil 1 AFT. Now, my transmission shifts normally. This is the best stuff that I have used.
MANUAL TRANSMISSIONS AND TRANSFER CASES
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON®-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid.
and
Use of manual transmission fluid part number 88861800 U.S. (88861801 Canada) in place of Dexron III.
Important Note: If the vehicle owners manual lists Dexron VI as the recommended transmission, transaxle or transfer case fluid disregard any information supplied in this PI. Use eSI and or the vehicle owners manual to determine what type of fluid should be used prior to referencing the below information
Recommendation/Instructions:
Manual Transmission fluid part number 88861800 U.S. (88861801 Canada) is currently available through GMSPO. Current and past model vehicles listed above with either a manual transmission or transfer case that REQUIRE Dexron III should use the above listed manual transmission fluid. This fluid is a direct replacement for Dexron III in manual transmissions and transfer cases. DO NOT use Dexron VI in place of the manual transmission fluid in any manual transmissions or transfer cases as a failure may result.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
That said, I do like their power steering fluid, and Purple Ice (the ONLY products of theirs that will ever be in my car!).
Don't know about early T56s, but don't think ANY fluid is going to damage an LS2 T56 in any way. I think it's just a matter of preference. I might try M1 ATF next time. Later.
JC
