View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
Old Mar 30, 2007 | 01:16 PM
  #261
ws6pewter's Avatar
Just put Pennzoil Syncromesh in last weekend and so far not much different. It might be just alittle more smooth compared to the oem ATF.
Old Apr 10, 2007 | 04:10 PM
  #262
ls1amit's Avatar
I use Royal purple syncromax. I would have a hell of a time putting it into first on occasion just wouldnt go in. So i changed the fluid out to this and it goes into gear alot easier. This could have been low fluid so on.. but my tranny has always been a bit noisy 89k on it but never grinded so I believe the fluid is doing its job! I recomend the RP syncromax from my personal experience just because it is working fine for me right now shifts are a bit notchy but i realy dont want to blame the fluid for that, just an older tranny.
Old Apr 11, 2007 | 11:13 PM
  #263
BLKWS.6's Avatar
I just bought the OEM Dexron III ATF from GM. It has the same SAE thickness properties as Mobil 1. It also shifted GREAT! even with 75K miles on it before I put in Valvoline which made things a bit notchier. I am going back OEM and think it will be fine. I have heard from numerous sources that RP will eat blocker rings, not b/c it is synthetic, but b/c the add-pack isnt very good for them.
Old Apr 12, 2007 | 09:42 AM
  #264
01pewterbird's Avatar
Was there any proof to the fluid being the culprit? And what year car/blocker ring material? I just can't see how a company such as RP would have a fluid specifically designed for modern manual transmissions and yet it eats blocker rings. I'd just like to see your "sources". If you have a link or something please post it up.
Old Apr 12, 2007 | 09:46 AM
  #265
MeentSS02's Avatar
Kleeborp the Moderator™
Well...Joe and Amber at Six Speeds Inc. don't recommend it anymore. That's enough for me to steer away from it (especially since they built my trans).
Old Apr 12, 2007 | 10:00 AM
  #266
That's interesting, I would find them to be a credible source from what I've read about them on this site. What exactly was their reasoning?
Old Apr 12, 2007 | 10:33 AM
  #267
BLKWS.6's Avatar
Any year. No T56 in ANY F-body had anything but paper syncros. I have no idea where the CF after 01' rumor came from.
Old Apr 12, 2007 | 10:55 AM
  #268
Realy? I beg to differ but only because I've read that on here so many times.
Old Apr 12, 2007 | 11:05 AM
  #269
LOL black WS.6, you once had the same belief as me untill the pros at Six Speeds Inc set it straight for you and the rest of us in this thread.https://ls1tech.com/forums/showthrea...=blocker+rings
Thanks for bringing it to my attention!
Old Apr 12, 2007 | 12:13 PM
  #270
BLKWS.6's Avatar
Old Apr 20, 2007 | 04:49 PM
  #271
5301113's Avatar
Royal Purple Syncromax works for me
Old Apr 23, 2007 | 08:13 AM
  #272
PoorMan's Avatar
I am using what the sticker says on the case. Heck, who knows better than the people that make it.
Old Apr 24, 2007 | 07:31 AM
  #273
coolformula's Avatar
Did t56 rebuilds put in there .02 cents? I figured they would know pretty well. Also the manf like poorman said.
Old Apr 24, 2007 | 03:29 PM
  #274
bad6as's Avatar
t-56 said mobil 1 atf and not to use rp
Old Apr 25, 2007 | 10:16 AM
  #275
FbodyAttraction's Avatar
I use Mobil 1, but to be honest, I liked the stock GM fluid better.
Old Apr 25, 2007 | 11:33 AM
  #276
getusum's Avatar
T-56 just did a viper conversion for me and replaced everything in the tranny except 1st gear...They personally recommended for my tranny 2 qts of syntergyn and 2 qts of mobil 1 atf.....just my 2 cents
Old Apr 25, 2007 | 11:36 AM
  #277
ONEBADASSWS6's Avatar
I've only ever seen them reccommend Mobil 1 ATF.
Thats what I use, along with a bottle of Lucas Trans Fix (to thicken up the fluid, it needs a rebuilt) and its been good.
Old Apr 25, 2007 | 08:01 PM
  #278
Whats syntergyn?
Old May 17, 2007 | 03:14 PM
  #279
bursty's Avatar
Hey guys, I went and got tons of fluids for my car yesterday (engine, tranny, and rear end) and accidentally got Mercon V instead of Dexron III. Will this work for an 02 T56?
Old May 17, 2007 | 07:35 PM
  #280
Mercon V and Dexron III should be the same stuff. Look on the back of the bottle, see if it says it meets GM Dexron III requirements. If it does, then you're good to go. I'm pretty sure Mobil 1 only makes one ATF, anyway, so that should be the stuff.
