View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
Old Dec 18, 2006 | 10:49 AM
  #221
MeentSS02's Avatar
Kleeborp the Moderator™
Originally Posted by SpdFrk1990
Someone said if you go back to d3 get all the synthetic out why is that? I thought about trying something like syncromesh or going back to reg dex3 but i dunno think im going to flush the clutch fluid tomorrow first. You know the more you read this thread the more confused you get lol. I did put some pennzoil syncromesh in a 02 civic tonight ill see how he likes that.
Not sure on that one...any of the synthetics I've used said they are fully compatible with any type of Dex III oil...synthetic or conventional.
Old Dec 18, 2006 | 07:38 PM
  #222
SpdFrk1990's Avatar
Yeh I was even thinking of trying 1 quart of syn and 3 of dexIII.
Old Dec 18, 2006 | 07:52 PM
  #223
03 BUSA's Avatar
I have been using Toyota/Lexus Type T fluid. $10qt. Have used it for 3 years and no problems.
Old Dec 21, 2006 | 10:49 PM
  #224
OneMeanZ's Avatar
Is the Pennzoil Synchromesh the same as the GM stuff?
Old Dec 21, 2006 | 11:00 PM
  #225
SpdFrk1990's Avatar
Its compatable I think my shifter might of got a little notchier cause the new fluid is thicker and not worn out.
Old Dec 21, 2006 | 11:41 PM
  #226
97LT1's Avatar
how often is T-56 fluid supposed to be changed? Im running redline fluid by the way.
Old Dec 22, 2006 | 09:02 AM
  #227
OneMeanZ's Avatar
Old Dec 22, 2006 | 12:13 PM
  #228
dailydriver's Avatar
As far as anyone can tell, Pennzoil makes it for GM. The only thing that would indicate otherwise is that GM offers a few different variants, whereas Pennzoil only offers one.
Old Dec 22, 2006 | 01:55 PM
  #229
OneMeanZ's Avatar
Alright thanks. Just got done putting the Pennzoil Synchromesh in my T56.
Old Dec 22, 2006 | 02:00 PM
  #230
SpdFrk1990's Avatar
If you look on the pennzoil bottle it says
* Meets GM Specification 9985648 and Chrylser Specification MS-9224
* Suitable for use in GM manual transaxles and transmissions requiring GM Part No. 12345349 or 12345577
Old Dec 24, 2006 | 12:05 PM
  #231
MeentSS02's Avatar
Bringing this REALLY long thread back up to the top, I'll put a nice plug in for Torco's ATF (fully synthetic). Not cheap, but some very nice fluid. It shifts better cold and warm (part and WOT when warm) than the Mobil 1 it replaced. Overall, I'm impressed. I flogged on it HARD this morning, and it shifted flawlessly.
Old Dec 24, 2006 | 12:27 PM
  #232
SpdFrk1990's Avatar
Nice never heard of that where did you get it?
Old Dec 24, 2006 | 09:24 PM
  #233
MeentSS02's Avatar
Just Googled "Torco", and ordered it straight from them. No hassles from them at all, and had it to me in about a week. Just be prepared for it to cost a pretty penny...it was certainly more than I paid for the Torco RGO for my rear end (non-synthetic though for the rear).
Old Dec 26, 2006 | 03:35 PM
  #234
Did you ask if it was hygroscopic or not?? Does it seem better than the Specialty Formulations stuff?? I know your T56 was modded/rebuilt, I wonder how the Torco stuff would be in a stock '00 T56? I guess I'll call them.
Old Dec 26, 2006 | 03:39 PM
  #235
MeentSS02's Avatar
Nope...I'm more of a "shoot first, ask questions last" kinda guy I'm assuming it is, but then again, I may be assuming too much. I haven't had the SF stuff in this transmission since break-in, so comparing it to that really wouldn't be doing it any justice. I'd be more than happy to give it another whirl for my next transmission refill though. It worked well in my old T-56, even though it was on its last legs.
Old Dec 26, 2006 | 04:09 PM
  #236
MeentSS02's Avatar
If you call them, post up the results. Otherwise, I'll give them a call and ask myself.
Old Dec 26, 2006 | 05:33 PM
  #237
MeentSS02's Avatar
Hmmmm...just got done talking to the Torco folks, and they didn't have a good, straight to the point answer. Their main point was that all oils absorb water to an extent, even if they claim to be non-hygroscopic. So I'm not too sure...I guess I don't know enough about oils to form my own opinion here. Thoughts? The Torco comes from Group IV/V base oils, so it has PAOs and some esters in it (and from my research, esters do absorb some water).
Old Dec 26, 2006 | 11:27 PM
  #238
TwistedSS's Avatar
I'm getting ready to change my clutch...I plan on changing fluid while im there. Ive got four quarts of Pennzoil Synchromesh ready to go.
Old Dec 27, 2006 | 07:22 PM
  #239
Yeah, that's why most will tell us to steer clear of the Redline D4, with it's "up to" ~50% ester base stocks. I'll have to grill Torco and try to find out just how much % ester bases they use. I just hope they don't give me the "propriatary, restricted info" answer that sooo many other "boutique oil" companies seem to give to contents questions. BTW; do you have any idea when SF will be back on line taking orders??
Old Dec 27, 2006 | 07:30 PM
  #240
INMY01TA's Avatar
I've been using D4 for bout 4 years. Works great.
