Which T56 fluid?
Chuck
i've just changed my trans fluid, and used about 3.5 quarts. do i not have the tranny quite level, and got about .3 qts too little in there? should i worry about this?
The Royal Purple Synchromax is a definate improvement but it will never be a ZF in shifting quality or strength. It is a bean counter solution for more profit.
I do know that with ATF lubed trannies you have to watch the additives and the type of lube you use. I also am 'told' that there are several iterations of synchros for this unit and some are very lube conscious - - the T56 is my chief complaint with the C6 next to the rear suspension.
Just my .02...
Chuck
I USE REDLINE..I WANT TO TRY SOME OTHER TO SEE IF IT MAKE A DIFFERENTS...HAS ANYONE DONE THIS????
Are you saying put friction modifier in the T-56?
