View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
53
8.85%
Royal Purple Syncromax
179
29.88%
GM Syncromesh
154
25.71%
OEM Dexron III ATF
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
Old Jul 2, 2006 | 10:52 PM
  #181
Domestic Demon's Avatar
Originally Posted by chucky2
Personally, I'd rather have it start leaking a little bit so I could take care of it, rather than run dino and have the whole thing just die a bad death one day (anyone seen that thread with the melted gears? )
Chuck
Same here, totally agree. I'd rather run the best (fully synthetic) fluid and risk having a seal leak than run the basic dino based fluid and have much more long-term wear on the trans.
I haven't see the thread with the melted gears, you have a link?? Sounds interesting, what happened, got too hot at the track running dino oil??
Old Jul 3, 2006 | 02:49 PM
  #182
chucky2's Avatar
Domestic Demon- That thread would be here:
No lube = T56 MELTDOWN! Pics...
Just to be clear, my point wasn't that a dino T-56 lube will cause this, rather, bur rather loosing a seal could cause this.
Chuck
Old Jul 16, 2006 | 11:02 PM
  #183
Robert56's Avatar
Originally Posted by Deeavi
I have done alot of research on engine oils and ATF. Mobil1 and Amsoil fully synthetics are the best!
I agree and use Mobil 1 synthetic in M12, rearend and crankcase.
Robert
Old Aug 3, 2006 | 08:46 PM
  #184
yellowbird1232's Avatar
Tech Fanatic
I had a conversation with the guys at keisler on the power tour about this. A friend was having a problem with a T56 he got from a shop online (very good reputation) and this is what was suggested. They have the guy who designed the T56. He said to use dextron. He explained it to me, the syncros use the weight of the fluid to effect the speeds of the blocker rings and speed gears. If you use a lighter of heavier fluid it will effect the operation of the syncros. I use dextron in mine and it's at the track 2-3 days a week. I check the fluid regularly and change as needed.
Old Aug 4, 2006 | 12:02 AM
  #185
I have heard the same thing from other sources. The gears themselves are not the issue, its the synchros that are designed to use ATF.
Its even imprinted on the trans case to use DEXRON III ATF, and I don't think they just put that on there for the hell of it
Old Aug 5, 2006 | 12:07 AM
  #186
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
redline D4
Old Aug 5, 2006 | 04:40 PM
  #187
INMY01TA's Avatar
Originally Posted by taner
redline D4
+1
Old Aug 24, 2006 | 02:46 PM
  #188
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I use Redline D4 ATF.
Old Sep 25, 2006 | 11:18 AM
  #189
asudecat's Avatar
still trying to understand this all.
Is RP Synchromax Synthetic? does it have dextron III?
I dunno what the hell to buy now. So many different opinions on this thread.
Im either leaning on RP Synchromax or Mobil 1 ATF.
Old Sep 25, 2006 | 11:30 AM
  #190
MeentSS02's Avatar
Kleeborp the Moderator™
RP Synchromax is synthetic, and it meets the Dexron III spec.
I just put Mobil 1 ATF in my freshly rebuilt T-56 from Joe and Amber (T-56 Rebuilds), and I'm VERY pleased with the results.
Old Sep 25, 2006 | 12:12 PM
  #191
2001CamaroGuy's Avatar
I have used GM Syncromesh, Redline ATF, and stock ATF. Of those three, I have been happiest with the GM Syncromesh as it seems to shift the best.
Old Sep 25, 2006 | 05:40 PM
  #192
jdoyle's Avatar
t56 rebuilds recommended mobil 1 atf for me.
also, lately i heard that tremec will only warranty damages if this fluid is run.
i ran synchromesh for about 500 miles and switched to mobil 1 ATF
Old Sep 27, 2006 | 01:12 PM
  #193
dailydriver's Avatar
Did you have problems with the Specialty Formulations stuff?? Could it have contributed to the recent rebuild???
Old Sep 27, 2006 | 03:16 PM
  #194
MeentSS02's Avatar
Not at all actually...the damage was done to my old T-56 WELL before I had ever used anything from Specialty Formulations. It was doing the typical popping out of 3rd BS Got tired of it one day, and decided to do a rebuild.
I ran the S.F. MTF Glide as the first fill in this new transmission, and it did very well. The only reason I switched it out was because I wanted to change the trans oil after about 1k miles just to make sure everything was okay (and it was). Joe and Amber (T56 Rebuilds) recommended the Mobil 1 ATF, and after looking at its properties compared to a lot of others out there, it seemed to be a pretty good match. The added benefit of being able to pick it up at my local Auto Zone for ~$6.00/quart was nice too
Overall, slow speed driving is just a LITTLE smoother with the Mobil 1, and hard shifting is the same to me.
Old Sep 27, 2006 | 08:04 PM
  #195
02NHRAtransAm's Avatar
this reminds me i should probablly do mine
Old Oct 11, 2006 | 11:33 AM
  #196
Rabidbandit's Avatar
All these fluids and not one mention of Dex/Merc V....the Dex III replacement? The bottle states that it's a synthetic blend that conforms with DEX III and III E specifications. We threw a few quarts in our trans...I'll let you know
Old Oct 11, 2006 | 12:37 PM
  #197
chucky2's Avatar
Rabidbandit- Mercon (and whatever roman numeral that follows it) is not a GM spec and will probably never be referenced by GM. I know you said Mercon V, however did you mean you put in GM's new Dexron VI?
The new Dexron VI starts at a lower cst @ 100C than Dexron III, 6.0 vs. approx. 7.5, so if that's what you're talking about, then you have a fluid with less viscosity than spec'd for. Whether or not that would be a problem is hard to tell...Dexron III is rumored to shear down, so if the new Dexron is more shear stable, does that really matter? Maybe getting a hold of the Dexron VI spec. would be a good idea here...
If you really meant you're running Mercon V, then you could be one of the first (if you're actually running just Mecron V and not a dual rated fluid)...it seems that most that go outside of the dino Dexron III spec. go for something more....hardcore (for lack of a better word)....fluid...
Chuck
Old Oct 11, 2006 | 02:00 PM
  #198
My bad...I was hearing everyone spouting off Dex III...Dex III...I assumed Anyway we have been using Advance Autoparts ATF with no problems except for some notchy shifting. Wear isn't even a factor...the damn trans is tight as hell after 50k and no shavings...(I filter through cheese cloth when draining)...and the new stuff is Valvoline Dextron/Mercon V...yes ford fluid. Willing to gamble according to the bottle...it has the same or better specs than the regular ATF that we have been running. It's seems to be a higher weight although without specifics...I could be wrong. I've been running it in my 4L60E in my blazer and tranfercase as well. It accually shifts better (less shudder) and temps are cooler...according to my little guage. If it works in that pile of crap and hasn't toasted the bands after 15k of heavy towing...then I thinks it's a safe bet...any thoughts I just tired of people thinking that you have to spend $15+ a freakin quart of synthetic-super-duper-fiction-eliminator to ease your mind of a trans failing. Do you think they had that crap back in the day runnin' down the track...uuuhh nope. I'm tryin' something new dammit
Edit: Found the specs:
Viscosity
cSt @ 100ºC 7.5
cP @ -40ºC (-40ºF) 10,500
Flash Point, ºC (ºF) 206 (403)
Pour Point, ºC (ºF) -55 (-67)
Gravity, API 34.1
Color Red
Mercon V satisfies Ford's new Mercon V specification, Ford Mercon and General Motors' Dexron-III, Dexron-IIE, or Dexron II specifications.
Mercon V is also acceptable in any Audi, Honda, Mazda, Nissan, Opel, Renault, Toyota and Volkswagen transmissions that require a Dexron-III, Dexron-IIE or Dexron-II type fluid
Old Oct 11, 2006 | 05:50 PM
  #199
INMY01TA's Avatar
I've tried Valvoline's Durablend atf and the Redline works much better.
Old Oct 18, 2006 | 01:49 AM
  #200
chucky2's Avatar
Rabidbandit- Looks like that would be fine running that in place of a dino Dexron III...I'm sure a Mercon V rated fluid has somewhat better basestocks than a just making it dino Dexron III rated fluid (especially the ones not H rated), so at the minimum, you should have at least a somewhat hardier fluid in there.
Hope it works out great!
Chuck
