View Poll Results: Which fluid is best for a M12 T56?
Redline D4 ATF
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
53
8.85%
Royal Purple Syncromax
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
179
29.88%
GM Syncromesh
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
154
25.71%
OEM Dexron III ATF
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
213
35.56%
Voters: 599. You may not vote on this poll
Which T56 fluid?
#121
Originally Posted by dailydriver
I wonder if the Amsoil Synchromesh shifts any better in the cold??
My '00 S10 is factory filled with Snychromesh and I changed it at 25k with GM Snychromesh.No differences.Just fresh fluid/maintenance.I then again changed it at 125k but didn't want to pay some ridiculous $20/quart so I switched to the Amsoil as it was new to the market and only $7/quart.After 15k miles nowI can honestly say it is more objectional to shift in the cold (mornings/NY weather here) than the GM Snychromesh was.Once warmed up it does shift easier and does feel a little better/smoother.I myself will leave it in as I go easy on it till it warms up fully,but if you tend to shift a lil rough in the first few minutes of cold driving you will get better/easier shifts with the GM stuff.
#122
now that the lucas additive has been in my car for a while, I do like it in warm weather or after the car has been warmed up for about 20 minutes or so. But when I pull my car to the track on a cold day on a trailer and unload it , I take it for a spin to get gear oil and trans oil warmed up but the trans does not warm up enough and I miss the 3rd almost every pass . In warm weather, It is great though. I beat the hell out of my car at the track to get good times but there is nothing that will **** you off more tehn missing shifts pass after pass when others look at you as a good driver with a stick and you cant make a good pass to save your life on a night with -1500 da
#123
Don't know if I've given my .02 yet.
Per my transmission rebuilder, who's rebuilt T56s for numerous hi-perf shops in my area, don't use Dex III. Only use Synchromesh or similar (either RP Synchromax or Amsoil Synchromesh). The Dex III is recommended by GM because it will lubricate the tranny internals better than the alternatives when cold, preventing unecessary wear from morons who don't warm it up before beating on it. But the Synchromesh will take care of everything MUCH better when warm, which is where 80%+ of your shifting is done (especially if you care about your car enough to join and post on a forum like this).
#124
I'll add an experience from this weekend. I've been running the Honda Z1 ATF for years now both in my 94 and my 01. I had an LS7 clutch put in about a month ago and I didn't have time to go by and buy some Honda ATF, so I told the shop to put in Dexron III. The tranny felt really notchy and I wondered if they didn't bleed the clutch hydraulics enough. I decided to change the tranny fluid yesterday back to Honda ATF and VIOLA, the tranny is shifting much smoother.
#128
no you can use that
syncromesh is good and the pennzoil should be to the same specs as the gm stuff
im using the brand of syncromesh that rockland standard gear sells
#129
I sell Acuras, and just went back to parts and picked up 4 qts of the Honda Z1 ATF. I'm about to change out my clutch and hydraulis in the next week or two, so might as well change tranny fluid too!
#133
Originally Posted by boondiggys
mobil 1...its gaurenteed fully synthetic
I've also heard good things about GM Synchromesh, I definitely wouldn't put regular old ATF in it though, especially if you run the car hard. Its worth the extra few bucks for the best protection for your rather expensive T56
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#136
Originally Posted by REDSS01
Pennzoil synchromesh...anyone? I just bought it by mistake.
Should I take it back to Autozone?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#137
The shop who rebuilt my tranny told me to use regular dex 3 atf fluid and not full synthetic because synthetics is to slippery for the syncros. I went to other tranny shops, and they told me synthetics is fine to use in our vehicle, but since the shop did my rebuilt i listened to him and put regular dex 3
#138
MeentSS02- Can you let us know how that lube works...MolaKule over at BITOG forums is highly respected, and that's his lube company he just started up.
Looking at the spec's, that seems to be a pretty kick 8ss lube...thicker when cold than ATF, but still, it should be pretty awesome just looking at the specs.
Even if the result is bad...can you still post back here? I'm just really curious to see how that stuff works...your the first I've seen post on using a SF lube in a F-body T-56.
Thanks!
Chuck
Thanks!
Chuck
#139
Kleeborp the Moderator™
Thanks!
Chuck
Thanks!
Chuck
BITOG is where I heard about this, and for the price, it really can't hurt to try. I was looking for Pennzoil Synchromesh, but since I didn't find any local, I just figured what the hell. Might as well give this a shot.
#140
MeentSS02- Thanks man! Got your PM...I'll bug you again in 3-4 weeks, just to see how it's going with the initial impression.
I almost can't wait for my FX4 Level II to get out of warranty...soon as it does, I'm ordering up some of MolaKule's stuff for my diffs and transfer case.
Chuck
Chuck
