408 w/ Dart 225 #'s ... A4
Old Apr 1, 2008 | 05:01 PM
junior28570's Avatar
Default 408 w/ Dart 225 #'s ... A4
As of last night, with just break-in time on the motor the numbers were;
482rwhp and 434rwtq
The car: 2002 WS6, full street trim
The set-up;
Built A4
Yank, SS3600
iron block, 408
Dart 225's (Bret Bauer enhanced)
Stock rockers
Custom Cam 23X/24X (Bret Bauer spec)
Ported FAST 90/90
85mm MAF
UD Pulley
AR 1 7/8" emission headers and catted Y (all emissions still hooked up)
LM1 (need to add some extra mufflers )
S60, w/ 3:73's
315 M/T's on 17x11 TTII's
Since there are a lot who know more than I do, I put my $$ in the most capable hands that I know of. I gave my engine builder, ***** Wiggins (Wiggins Racing), a simple outline, "<10.99 full weight car and 16mpg (or better)". He got with Bret and together mapped out this set-up. I can't verify the mpg yet but the dyno numbers suggest the ET's will be there. *****'s dyno numbers are usually a little lower than the rest in our area (I've seen as much as 20hp difference) so, I have the most confidence I'll get the ET's to match the numbers.
A graph is on the way!
Old Apr 1, 2008 | 05:36 PM
DrkPhx's Avatar
Those are good numbers for an stalled A4 with a Dana S60 and 3.73's. Do you know your actual raceweight?
COOKIE MONSTER's Avatar
Yeah, nice job Junior. I'm happy/Jealous for you.
But I'm still looking at 470+rwhp. Unless ***** sabotages me. lol.
So, question is, are you gonna dyno on Sat?
Old Apr 1, 2008 | 05:40 PM
waterbug1999's Avatar
Do you know how much $$ BB charged and what did he do to your heads?
Old Apr 1, 2008 | 05:41 PM
No, I don't know the actual raceweight. The only thing removed from the car is the front sway bar (10lbs??) .. everything else I've put on it weighed more than what I took off so .. she's a pig!
Yes Vos .. I'll be there! Enjoy the high HP stock 10 bolt while you can! That 9" and 4:10's are gonna sap the life out of your numbers
Old Apr 1, 2008 | 05:46 PM
I'll put down 430-440 on a calibrated dyno after with my 9" and 4.10s.
And, My 402 will be well built for next year, with a lot-o-something extra. ie 88mm and or 150-250 shot. Can't wait to drag your 408 down KDS, NAM, CPD, or on the Street. lol
Here comes the **** talkin'! lol
Old Apr 1, 2008 | 05:49 PM
I had busted a couple pistons on my 346 so they needed a little cleaning up. I had 3 bent valves to boot. To deck the heads, valve and port work, set the springs (set up to match the cam specs) etc .. very reasonable! PM me and I'll get you the finer details!
Old Apr 1, 2008 | 05:51 PM
You talk as if this is build is over .. tisk tisk ..
Old Apr 1, 2008 | 07:14 PM
I was wanting to get my Dart 205's ported/cleaned up since I have to pull them off the car due to a leaky head gasket.
I was just wanting to compare quotes/prices.
Old Apr 1, 2008 | 07:53 PM
willyfastz's Avatar
Restricted User
What do you mean "on a calibrated dyno"? Who around here has a dyno with a Eddy current brake? That's the only thing that has to be calibrated.
Junior you 408 should handle a decent shot of Nitrous as well. The rings are already gapped for it.
Old Apr 1, 2008 | 08:20 PM
zigroid's Avatar
great numbers! bret really knows how to spec a combo
Old Apr 1, 2008 | 09:42 PM
venom ws7's Avatar
Awesome numbers man Congrats with that REAR,Stall and catted Y-pipe.
Can you share the lift and LSA on the cam??
Where the hell did you get MT 315 35 17 those tires are backorder everywhere???
Old Apr 2, 2008 | 12:06 AM
dont thowin' ATVs and deisels on there through cailbration??
Old Apr 2, 2008 | 12:07 AM
Ohhhhhh ****! here we go! lol
Old Apr 2, 2008 | 02:51 AM
Understandably, Bret prefers to keep some things off the boards. Feel free to PM him, he's not too hard to find
I've had these M/T's for about a year. I've only got about 200 miles on them so far .. but that's fixing to change I have been following the backorder thing ... I heard they had lost DOT certification though???
Waterbug .. Bret's Dart 205 CNC program will far outflow what was done to these 225's. I would PM him for a quote .. his 205 work is amazing!
Old Apr 2, 2008 | 06:42 AM
willyfastz's Avatar
Restricted User
Or you can just pm me for pricing on Brets port work. His CNC Dart 205 heads flow 345+, but that may be way more than your wanting. You may just want some cleanup and a valve job.
Old Apr 2, 2008 | 07:40 AM
PewterScreaminMach's Avatar
Wow, strong numbers.
Old Apr 2, 2008 | 08:16 AM
Yeah not at all considering the TC, gears, and MTs on the dyno.
***** has a very good reputation around here.
Old Apr 2, 2008 | 11:37 AM
Stang's Bane's Avatar
Jody, whatever you spend with Bret will be more than worth the money.
If you talk to him alot, you may learn a little also. I know I did.
Old Apr 2, 2008 | 03:13 PM
SEB's Avatar
SEB
Damn good numbers man!
