6an fitting to flared hard line with oring ?????
Old Jun 6, 2017 | 09:12 AM
gsxrred1000's Avatar
Default 6an fitting to flared hard line with oring ?????
Will my return line 6an braided seal on this flare with the oring ? If not what can I use ? It is a 5/16" hardline. Hose threads on good and seems to seal but it's behind the seat in a c10 pickup so wanna make sure I'm good or not. Stock truck fuel regulator and rails on a 255 pump so I'm assuming 58psi.
Attached Thumbnails 6an fitting to flared hard line with oring ?????-img_2119.jpg   6an fitting to flared hard line with oring ?????-img_2121.jpg
Old Jun 6, 2017 | 09:48 AM
stevieturbo's Avatar
I would say absolutely not, and 5/16" is not a typical size for -6
What used to screw onto that ?
Old Jun 6, 2017 | 10:09 AM
It's new. Used an 18" piece of 5/16" line threw the sender and it already had flared end and fitting on line. The fitting size must be 3/8 because it screws onto the 6an perfect. I know it's not the correct flare on the end but wasn't sure if the oring would squash as the seal.
Old Jun 6, 2017 | 10:35 AM
Floader's Avatar
looks like a power steering fitting..... dont try and attach a AN line to that.... Dont want to catch on fire do ya?
Old Jun 6, 2017 | 10:52 AM
gjohnsonws6's Avatar
Inverted flare adapter. Russell sells one. Not sure if that's the right size for you. Also check out Pure Choice Motorsports. They have several sizes.
Old Jun 6, 2017 | 10:53 AM
Great thanks for input. I'll check it out.
Old Jun 6, 2017 | 10:59 AM
LS1-IROC's Avatar
Looks like a standard GM "saginaw" fitting. You can get adapters to go to -6 AN
Old Jun 6, 2017 | 12:54 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Does no one else recognize its a screw in iso flare fitting for like a fuel filter? You dont use those brown orings for anything but fuel. they wont work well for power steering. Thats a type that screws into a fuel filter. Cut the line use a compression adapter to an.
Old Jun 6, 2017 | 03:19 PM
Nitroused383's Avatar
I'm not sure if this will work, but I used one of these except in 3/8 to adapt to my stock feed line.
http://www.speedwaymotors.com/LS1-LT...FYhsfgodMDQA1w
