CNC Ported 243 Heads
Category: Engine - Power Adders
Price: $1650
Location (State): MA
Item Condition: Brand New
LS Engine?: Fits LS Engine
For sale is a set of 243 heads CNC ported by FlowTech Induction. I bought the heads used off of this site and had FlowTech run their CNC program on them, new valves, etc. They have new Lunati dual valve springs installed. The heads are not milled. I planned on running them on an LQ9 so I'd have stock LS2 compression. I have never run or installed these heads since I had the porting done. They have been sitting in my basement since. I have also attached a PDF of my invoice from FlowTech.
I have about $2,200 into these. New price $1,650 and I will cover shipping if needed.
Description of them as follows from Ed at FTI:
Here's the description with the race ported heads using new stainless valves.
Cylinder Head: LS2-LS6 – 243 Casting
Port Volume: 234cc
Chamber Volume: 67cc
TestBore: 4.000"
IntakeValve: 2.020"
ExhaustValve: 1.570"
ValveLift Intake Exhaust No Pipe
.100" 65.7 55.1
.200" 145.8 119.9
.300" 197.7 162.7
.400" 245.0 187.7
.500" 282.0 200.1
.550" 299.1 204.0
.600" 305.2 208.0
i do not believe the cost included the price of the 243 cores. If you read the OP's post again, you will read that he purchased the heads used THEN that the Flowtech work performed.
Yes that is correct. Thanks for the help, Cali_bear and LLL. I had to buy the heads then have the CNC work/valve springs done. You're basically getting unused (post CNC porting) CNC ported heads with dual valve springs, without the cost of buying the heads. Seems like a good deal to me.
