Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
*ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++
Old 01-03-2018, 11:38 AM
N/A86's Avatar
Default *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++
Category: Accessories
Price: $123
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
-LS1/6 Fuel Rail & Injectors NEW
Rail#125606891
Injectors#12554271
$225
-Set of 8 LS1/6 Fuel Injectors in good working condition
$110
-Set of 8 NEW Fuel Injectors.. Bodies read "H-30" and nothing else... Larger body diameter than LS1 style injectors..
$125 obo
-OEM ECU (Red/Blue)#09379551/16220610
-GenIII Fbody/ LS1/6 MAF Sensor...78mm
$45 obo
-GenIV Truck MAF sensor 90mm
$75 obo
-Granatelli Performance MAF Sensor 90mm Lightly Used
$125
-F-body LS1 GenIII Throttle Body 78mm (DBW)
$45 obo
-GM Truck GenIII 3-bolt Throttle Body (DBC) w/IAC & TPS Sensors
$55 obo
-GM Truck GenIV 4-bolt Throttle Body (Gold Blade...DBW) 90mm
$75 obo
-F-Body LS1 A/C Compressor Bracket w/Idler & Tensioner pullys
$50
-GM GenIV Truck Coil Pack Set.. With Brackets, harnesses, 8 working coils & 8 spark plug wires with steel heat boots
$150
-GM GenIII Truck Coil Pack set HEAT SINK with brackets, coils, harnesses and plug wires...
$200
-Stock OEM GenIII&IV Valve Covers, Valley Covers, Oil Fillers, Breathers, Coolant Crossovers (Including 4-corner $100obo) gaskets, Crank & Cam sensors, lifter trays, Cam Sprockets, New Crank Bolts... So So Much Crap!!!!
-GM LS1 Flexplate NEW
$50
-New Bosch O2 Sensors (98-02 Fbody)
$75ea
-Lightly Used low mileage ACDelco O2 Sensors (98-02 fbody ls1)
$40ea
-New O2 Sensor Extension Harnesses (Different Lengths will include with O2 sensors)
-GM GenIII Truck Intake Manifold LOADE...All Sensor's & Fuel Injectors/Rails...
$100 obo
-GM GenIV TBSS(Trail..Blazer..SS) Truck Intake Manifold..LOADED COMPLETE
Rail# 60728823/12580422
Injector#12580681
Manifold#00051094/25344694/0517811039.. Have pig tails/clips from harness side with a few inches of wiring remaining
$225
-SLP Air Lid for 98-02 GM F-body... With Air.Intake.Temp. Sensor, Smooth Below w/clamps & Nice K&N Air Filter Assembly
$100
-98-02 F-Body K&N Air Filter/Cleaner w/Cleaning Kit
$30
-GM GenIII/IV LSx Rocker Arm Sets...Low Miles, Includes 16 Intake/Exhaust Rocker Arms (Fits all GM GenIII/IV LS Engines EXCEPT LS3/LS7 W/Offset IN Rockers) , 2 Rocker Arm Stands and 16 Rocker Arm Bolts...
$75
-GM LS GenIII/IV Hydraulic Roller Lifter Sets..Used with Low Miles in good working condition, can include GM Lifter Trays and Bolts and stock length pushrods as well...
$50
-CompCams/Texas Speed MS4 Camshaft NEW NO RUN TIME... Hydraulic roller #'s413910/315605....Engraved #'s25-MS4/VV5231-12/12-EJ...244...3-BOLT CAM
$300 obo
-GM GenIV Aluminum "H.O." 5.3L Short Block...Mileage Unknown, Includes Truck front accessory drive, D.O.D. Valley and GebIV front & rear covers
#66110053/51153/V027...932
$400
-GM OEM Torque Converter #2630_D-2/TMBX 2422/7948
-NEW GM OEM Water Pump LS2 #12600468
$160
-GM Truck Exhaust Manifolds
$65
-OEM Fbody 98-02 Manual pedal assembly with all electronics (Gas pedal has been removed for a third gen swap)
$75
-F.A.S.T. Upper too Lower intake manifold gaskets...
-OEM Truck? Plastic ECU Bracket
-OEM Truck Fuse Panel
-Aluminum Adj. Wilwood Master Cyl... Neal Aluminum Clutch pedal & bracket assembly (mounts down with pedal up or hangs with pedal hanging)
-Tilton Adj. Master with Remote Reservoir
-2 Used Aluminum Remote reservoirs with -6an feed/return & vented caps with -3an braided vent lines
-Nice Aluminum Remote Reservoir with Cooling Finns, -6an feed/return/-3an braided vent line off cap... And BUILT IN Oil Filter/P.S. Filter....
$110
-GM GenIV LS2 Short Block w/55,xxx Miles... Good Shape, Can come in different ways... As a short block $1,450
-SBC 350 .030" over 010 High Nickel 4-Bolt Main Block... Short Block with all front drive accessory's, pan, fuel pump, Flexplate, HEI dizzy, smog GM heads ...
$550
Can come with...Aluminum Performer Intake...Holley Dual Plane Intake...Holley SpreadBore 650...Holley Square Bore 650...Edelbrock ValveCovers...And More...
-MOROSO Race Valve Covers...<1986/GenI SBC perimeter bolt TALL thick Aluminum valve covers... 1 solid, 1 with 2 breathers with 3" risers... Raised "MOROSO" lettering
$75
-Texas Speed Stainless Steel Long Tube Headers, 1-7/8" Primary's, 3" Collector's...w/Stainless Steel fasteners
$300
-Vortex High Pressure Fuel Pump...FI lightly used 340lph
$125
-OEM Transmission X Members
Auto's 10405540 & 10195323/10198346
Manual's 10405541 & 10438098
Stock Springs
OEM Torque Arm Mounts
OEM third gen 3" catalytic converter flange (2-bolt)
OEM third gen exhaust hanger transmission bracket
*GM 7.5" 10 Bolt Parts...
-Used GM Torsion Posi Unit
$125 obo
-New Auburn Style Posi Unit
$225 obo
-New 3.42 Ring & Pinion Gear Set
$100
-New 3.73 Rung & Pinion Gear Set
$125
***10Bolt Package Deal***
-New Auburn Style 28Spline Posi Unit
-New 3.42 OR 3.73 Ring & Pinion Gear Set
-New Perfect Launch Aluminum Girdle w/Adj. Carrier Bearing Cap PreLoad Lash Caps
-A.R.P. Carrier Bearing Cap STUD KIT...
-Stainless Steel Long Rear Cover Bolts
-2 Quarts of RedLine Gear Oil
-New tube of RTV
-New Fel-Pro Rear Cover Gasket
-New Timken Axle Seals
***All the above listed $500***
Tremec LS T-56
***Popped Out of 4th Gear***
*Missing Input Shaft*
-Includes LS Belhousing
$1,350
-New SPEC Performance Stage-1 Clutch Assembly with New GM Flywheel
$390
*LS1 Fbody Rear Disc Brake Kit...
-Slotted & Drilled 11+" Rotors
-Newer Quality Brake Pads
-OEM PBR Calipers & Brackets
-All Necessary Hardware
-OEM Rubber Hose Holding Brackets for Axle
-Rubber Brake Hose's
-New OEM Backing Plates w/New E-Brake Shoes/Hardware
-E-Brake Cable's
-Sheet Metal E-Brake Cable Bracket (This bracket was riveted into the transmission tunnels of the 98-02 fbodys... It is where the Parking brake handle's cable is attached too the 2 rear cable's...I cut it out of the car to help with a totaly painless install for third gens)
$385
-New GM 93-02 Fbody Rack & Pinion
$75
-New GM 93-02 Fbody Steering Shaft w/Universals
-1998-02 Camaro Z28 Grille in good condition with no cracks
$75. NOT SLP/SS GRILLE
-93-02 Fbody Coolant Reservoir
$50
-93-02 Fbody Windshield Washer Fluid Reservoir
$45
-93-02 Fbody Brake Master Cylinder & Power Booster w/Proportioning Valve
$65
-98-02 Fbody Front Spindle Assembly with hub's
$50
-93-02 Fbody Upper and Lower Front Control Arms/A-Arms with new ball joints and Poly Bushings...Can include Poly Front&Rear Sway Bar Bushings & Performance Poly Endlinks...
-93-02 Front Sway Bar.. From a clean 2000 SS SLP Car, Measure's 33mm. Includes Poly Bushings and Performance Endlinks w/Poly...
$100 or $65 obo w/o poly extras
-82-92 Fbody WS6 Front Sway Bar 36mm with Performance Poly Bushings, Brackets & Endlinks
$100
-82-92 Fbody Rear Sway Bars 19mm & 21mm obo w/Poly Extras
-82-92 Fbody IROC-Z28 OEM Coil Springs
$80
-82-92 Camaro Fenders OEM good condition not perfect $70ea
-82-92 Camaro Fenders NOS New $150ea
-82-92 Camaro Radiator Support NOS New $125
-82-92 Fbody TPI TunnedPort Rubber Snorkel Below
-85-92 Fbody/Camaro Air Filter bucket custom fabbed steel brackets for CAI set up
-82-92 hood hinges
$35pr
-82-92 Firebird Gauge Cluster
$75
***FULL TURN KEY NITROUS SYSTEM BOLT IN AND GO FOR FBODY LS1***
-Nitrous Controller...Timing Delay, RPM, Gear...Curve lots more adj...
-Harness that plugs into LS1/Fbody Crank sensor... Existing harness then plugs into this... Works with 98-02 Fbody ECU...
-15' Stainless braided -6an nitrous feed line (also an extra 8' or so)
-all needed fittings
-Blow down tube
-2 10lb bottles (NEW)
-Bottle Brackets
-All Solenoid drivers...
-Purge Solenoid
-Nitrous Solenoid
-Fuel Solenoid
-Nitrous prs. Gauge
-Fuel prs. Gauge
-Bag of jets...50hp-250hp
-90mm Nitrous Express Plate OR 78mm...
More I am forgetting....
Turn key set up $1,175
***Strange Engineering 12-Bolt Axle with EXTRA's***
-Upgraded housing
-"Big ford" bearing ends
-Welded axle tubes
-Upgraded HD Strange 33spline axle shafts
-2"x5/8" ARP wheel studs
-33spline Strange spool
-4.56 Richmond "Race Series" Gear Set
-11" Drum kit($400 option... Can be swapped to the PBR/LS1 Style Rear discs for an extra cost and I can do it before shipping)
-HD Chromoly 1350 Pinion Yoke
-HD U-Joint Strap kit
-LCA Relocation Brackets with stock/1"/2" & 3" Drop choices
-Third Gen 82-92 Fbody dimensions/ Width....
-DOES HAVE T.C.S. Provision Hole...
Also included in the deal is the following
-3" Driveshaft
-Chromoly
-Chromoly 1350 transmission yoke
-1350 HD U-Joints
-Tubular Torque Arm (believe its mild steel) with stock style front mounting bushing...
-HD Bracket for mounting the torque arm too the diff... This diff DOES NOT.. Have the weaker style torque arm mounting style... It is the improved style... Also it is not a standard 12 bolt housing... Not a GM or Moroso based design...
All price's are OBO before any paypal fee's or shipping costs unless stated otherwise... Feel free to make offer's, ask for item's not listed, offer up trade's, make package deals for lower price's (Im broke so I need the cash!!!) or ask any questions....
***SO MUCH MORE.... CALL OR TEXT FOR ANY AND ALL YOUR OEM & PERFORMANCE FBODY/GBODY/SBC/LTX/LSX And almost any OEM or Performance 82-92/93-02 F-Body...SBC...LSX Parts as well as many other Performance Parts from Nitrous Systems too NASCAR Wheelin Modified Tour race car parts ...***
***Please include your name and what you are inquiring about in your PM/Text***
Call or Text me @(716)428-1674
Thanks,
Adam B.
Will update this and make a more complete list... Also will add more part numbers... No pics unless you are serious and TEXT me
Attached Thumbnails *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_113803.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_113539.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_112617.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_112546.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_112525.jpg
*ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_112458.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_112325.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_065922.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_063536.jpg   *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++-20180104_063105.jpg
Old 01-04-2018, 02:14 PM
N/A86's Avatar
BUMPITY TTT
3.73's Sold MAKE OFFER'S IF I AK ASKING TOO MUCH FEEL FREE TO OFFER A PRICE
Old 01-07-2018, 01:57 AM
N/A86's Avatar
Some pics added... Make offers am broke....need cash and dont need piles of parts. TEXTS are preferred as I don't get on here that often... Please include your name and what your inquiring about...
Thanks,
Adam B. (716)428-1674
Old 01-12-2018, 09:45 PM
duggravs's Avatar
Do you still have the f-body a/c bracket?
that' the one that bolts to the lower passenger side of the black right?
Old 01-16-2018, 11:27 AM
Z282002maro's Avatar
do u have the y pipe for the headers
Old 01-17-2018, 10:11 AM
96darkhorse's Avatar
Any LS6 valley covers?
Old 01-18-2018, 02:24 PM
510pewterSS's Avatar
Text sent
Old 01-18-2018, 02:47 PM
Chantro's Avatar
HI, I'm looking for gen 4 rods, gen 3 or 4 crank, gen 4 flattops. I'm rebuilding a LQ4 for my 98 camaro z28.
Old 02-01-2018, 07:35 AM
L33
L33's Avatar
-New tube of RTV
WILL THIS GO INTO AN S10 7.625 Rear End??
Old 02-01-2018, 12:54 PM
jackchappell's Avatar
Default Interested
I'd like to get the lifters and trays. Pmd you
Old 02-02-2018, 08:55 PM
OMSR's Avatar
sent a text message about the 10 bolt stuff from a area code 678
Quick Reply: *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++
