Fikse wheels, some aftermarket parts, stock ls1 parts etc.
Category: Racing Parts
Price: $0
Location (State): SC
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Hunter Clamp
704-258-8718 Call or Text
Aftermarket Parts:
-17x9.5 front and 17x11 rear, forged & polished, Fikse FM10 wheels. These are high end lightweight wheels that are hard to find. These are in great shape and only have light imperfections from driving. I will sell with or without tires. These were on my 02 SS Camaro and will fit any 98-02 Camaro, Trans Am or Firebird. The tires are Nitto 555 fronts and Nitto NT05R drag radials in the rear. The tires have less than 1,000 miles on them, but do have the normal cracking that they get over time. $3,000
Outer rim 2.5 X 17
Inner rim 7.0 X 17
Outer rim 3.0 X 17
Inner rim 8.0 X 17
9.5 X 17, +38mm Offset
11.0 X 17, +44mm Offset
-NIB All star battery cut off switch $40
-Autogauge 2 5/8 mechanical gauges in oil pressure, volts, water temp --- hooked up and removed $75
-NIB Stage 8 locking collector bolts #8950 (2 boxes contains 6 bolts each and hardware) $20 each
-NIB header gaskets brand unknown $10
-(2) NIB throttle body to air lid couplers with hose clamps $5 each
-5.57 12 bolt gear, low miles $150
Stock Parts some new & used (Less than 40k on everything if not new):
-NIB GM coolant bypass pipe seals for ls1 requires 4 #12551933 $24 for set of all 4
-NIB GM crankshaft balancer bolt for ls1 #12557840 $5
-NIB water pump belt $35
-Rear seat belts a pair ebony $50
-(2) Rear trunk covers ebony $25 each
-Front headlamp set (Lt & Rt) $150
-Right headlamp needs reconditioning $25
-(2) Windshield washer tanks $25 each
-Front bumper absorber $25
-Delphi MAF $75
-AC Delco amp $25
-Thermostat $5
-(1) M6 Trans cross member $50
-Stock cam, pushrods, valve springs, retainers, locks $100
-Emergency brake shoes $50
-ABS block $100
-Air box assy $100
-Heating system out of 2000 SS $100
-Traction control system off 2000 SS $50
