Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Mega LT1 parts list
Old 07-05-2018, 09:32 PM
JasonShort's Avatar
Default Mega LT1 parts list
Category: Accessories
Price: $1
Location (State): NY
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
There are a lot of parts here and I don't have the time to type up a detailed description for the condition of each one; however, just let me know what you are interested in and I'll be happy to provide you with all the information and pictures.
Overall, everything is in very nice condition. All parts are used with the exception of a few that are denoted as "new". I don't sell junk.
Feel free to make a reasonable offer on any of this stuff. I'll make nice package prices to anyone wanting multiple items as well.
-T56 transmission removed from a 1997 Z28 with 50k miles. The transmission was recently rebuilt with new synchros (only needed a 2nd gear synchro) and has around 1500 miles since that point. It was rebuilt using OEM components (no upgrades). The transmission is in excellent condition and has zero issues. Includes all sensors (VSS, reverse lockout, etc..) and bellhousing w/slave mount. $1300
- AFR 210 LT4 Eliminator heads ported by Lloyd Elliot (new). 75cc chambers, fully assembled. I have all the flow numbers. One head needs a very small repair. Apparently a defect from AFR that escaped through quality control. Probably less than $30 to fix. These heads are over $2600 new. $1600
- LT1 polished alternator, 140a, $75
- Kenne Bell Boost-A-Pump, brand new, includes 2.5psi hobbs switch (also new in box) SOLD
- Trickflow 44lb injectors, very low miles, part number 89044, EV1 SOLD
- LT1 3.5" MAF sensor $35
- F-body rack/pinion with PS pump and reservoir (61k miles) $100
- 96-97 timing cover $75
- Comp Cams Magnum 7.200" pushrods (new) $60
- LT1 flywheel (recently resurfaced) $50
- Camaro side mirrors (R and L) $80
- LT1 intake manifold $30
- Spec 4 clutch $40
- Autometer boost gauge $20
- Corbeau A4 seat w/F-body mounting bracket $150 (will not ship)
- Crane ignition box/PS91 coil $100
- 72lb injectors. Low impedance. $125
- 96-97 LT1 M6 engine harness w/Acceleronic impedance converter (used with above injectors) $200
- MSD 8.5 wires $30
- SS billet aluminum round shift ****, anodized black $20
- Bilstein HD shocks (front/rear) $125
- Autometer 5" tach w/shiftlite $100
- Energy Suspension poly motor mounts mounted in LT1 clams. Upper and -
lower mount complete (new) $90
- Prothane poly motor mounts in LT1 clams. Upper and lower mount complete (nearly new) $80
- HKS SQV4 blow off valve $100
- 94-97 LT1 fuel rails, great shape w/all hardlines and regulator $40
- 96-97 LT1 timing cover, waterpump drive hole sealed (for use with electric pump) $40
- T56 inspection cover $20
- Stock LT1 throttle body w/airfoil, IAC, and TPS sensor $45
- Professional Products 52mm throttle body w/TPS and IAC sensor $125
- 96-97 LT1 coil/ICM. Excellent working condition. $25
- LT1 M6 F-body (93-97) transmission crossmembers (no corrosion, like new) $30
- Borla XR1 3" in/out muffler, very low mileage ($140 new) $80
- PCV valve w/rubber elbow and hardline to front of intake $15
- (2) LT1 starters $30/ea.
- Energy Suspension polyurethane transmission mount $20
- T56 lower shift boot $15
- LT1 3.5" MAF sensor w/screen $35
- LT1 3.5" MAF sensor, no screen $30
- Billet aluminum "Z28" badges (new) $50
- 96-97 LT1 M6 engine harness, very nice shape. Removed from one of my personal cars just last week. Verified to be in perfect working condition and has no missing connectors. $200
- OBD2 LT1 PCM, currently tuned for stock motor with 8psi of boost and 44lb injectors SOLD
- March underdrive pulley set (crank and alternator pulleys) $60
- F-body M6 torque arm mount w/bushing $25
Old 07-05-2018, 11:12 PM
curacaoz28's Avatar
Is the crane ignition box a btm?
Old 07-06-2018, 07:38 AM
cino's Avatar
Interested in T56 lower shift boot. Pm sent.
Old 07-06-2018, 07:43 AM
biketopia's Avatar
I know it's a long shot, but you wouldn't be happening to be going to one of the Carlisle swap meets this year would ya? I'm interested in the seat.
*edit* Also realized a buddy is taking his car to the Syracuse nationals later in the month, happen to be planning to go to that??
Old 07-07-2018, 08:45 PM
JasonShort's Avatar
No it isn't, sorry.
PM returned
I usually go to Corvette's at Carlisle, and sometimes the Syracuse Nationals. I'm undecided exactly what events I'm going to go to this summer but should have things figured out soon.
Old 07-08-2018, 10:31 PM
PARMY's Avatar
What year is the intake manifold from? Would you take $175 for the new engine mounts, the timing cover and the intake plus shipping to Ontario, Canada.....provided the shipping isn’t crazy.
Old 07-09-2018, 07:07 PM
Camaroman94's Avatar
I'll take the t56 inspection cover
Old 07-10-2018, 04:40 PM
94purplepearl's Avatar
Default 52 mm throttle body
I would like the throttle body how bout 90$ shipped to WA 99337?
Old 07-11-2018, 06:38 AM
biketopia's Avatar
Ok cool, keep me posted if the seat doesn't sell prior.
Old 07-15-2018, 01:53 AM
How much for the inspection cover shipped to 95403?
Old 07-15-2018, 08:27 AM
Bengtson95's Avatar
Pm sent about the shocks, alternator and badges
Old 07-19-2018, 06:37 PM
CorbinD's Avatar
PMed about t56 torque arm mount
Old 07-22-2018, 08:14 PM
dagridiron01's Avatar
Are shocks sold yet?
Old 07-25-2018, 06:58 AM
southern_chevy's Avatar
How much for starter and transmission mount shipped to 70754? Thanks
Old 09-08-2018, 08:38 PM
Still have the inspection cover?
Old 09-09-2018, 03:10 PM
tnmotown's Avatar
Pics of the spec clutch?
Old 09-24-2018, 05:40 PM
talbotdd's Avatar
Default Pm sent
Pm sent
Old 09-26-2018, 03:21 AM
curacaoz28's Avatar
hello stil have the intake elbow?
Quick Reply: Mega LT1 parts list
