Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
LT1 Performance & Stock Parts, 383, 24X, etc.
Old 07-25-2017, 12:33 AM
383z's Avatar
Default LT1 Performance & Stock Parts, 383, 24X, etc.
Pictures in the link below.
https://houston.craigslist.org/pts/6212634784.htm
383 stroker with forged internals. $2500
Built 4L60. $800
TPIS headers 1 3/4 inch headers to 3in collectors. They have some dents and they have been sandblasted and coated with POR-15 high temp paint. $200
BMR K-member that is powder coated black. One of the welds broke and I had it welded again. $250
Canton 7.5 oil pan with the gasket. $200
New LT1 Melling oil pump M--55HV ($40 new) with new welded on Canton filter($37 new). $50
New LT1 water pump that was painted to prevent corrosion with gaskets. $50
LT1 water pump that's bad that the housing can be used for an electric water pump. $5
LT1 power steering pump with pulley. $30
New crank and hug bolts. $30 and I paid $32 plus shipping,
LT1 lifter spider and bones. $15
LT1 oil tube $20
LT1 alternator $40
LT1 stock injectors. Only 7 of themfor$20
LT1 motor mounts $20
Trick Flow 7.200 .080 push rods $60
LT1 A/C accumulator mount bracket $7
LT1heater hose line$30
LT1 polished head steam crossover line $40
LT1 accessory bracket $100
LT1 A/C compressor $175
LT1 A/C dryer line to accumulator $10
LT1 power steering reservoir with hoses $25
LT1 abs module with master cylinder $50
LT1 oil pump drive
LT1 power coated thermostat outlet $15
LT1 water pump shaft coupler $30
LT1 power steering reservoir cap in real good condition $20
LT1 ARP Head bolts 12 point. Use to bolt down heads and then unbolted them. $50
LT1 ARP HD Oil pump drive shaft put in and not even ran. $15
Everything needed for a24X conversion:
New 24xcrank reluctor
Newcrank position sensor (attached to timing cover)
cam sensor housing
New 1x cam reluctor
New Cam position sensor
New cam sensor housing
New 96-97 crank key
96-97 timing cover that's been powder coated with seals and new crank position sensor.
LS1 PCM bracket
LS1 0411 PCM
New 96-97 hub
EFI Connection ignition coil brackets with coils
New A/C Delco LS1 coils #12573190 #D514A.
24X BP Automotive harness for a 93 F-body with A/C and MAF. This was attached buy never used. $500
New LS1 stock MASS air flow filter $80
New SBC valve covers $100
New Fel-Pro head gaskets
New LT1 Stainless steel throttle body bolts $8
New LT1 Stainless steel water pump bolts $15
New LT1 Rear coolant crossover pipe bolts and washers $20
New LT1 Stainless steel intake bolts $20
New LT1 Stainless steel bolts for fuel rails free if you buy something!
Polished fuel rails $50
Aluminum elbow semi polished. $40
Like New Arizona Speed and Marine 58mm throttle body that's been repolished and rebuilt. $350
Billet Specialties Push-on oil fill caps. $40
Like new (used once) Sealed Power 224-15057 oil screen installation tool. $20
LT1 throttle linkage bracket $5
TPIS intake block off plates $10
LT1 intake with injectors and fuel rails. $30
New BMR Driveshaft Tunnel brace. $40
New Craftman Wrench organizers. $5 for both.
LT1 spindles with brakes $40
Pictures coming soon!!!
Old 07-27-2017, 12:22 PM
LT1firetank's Avatar
You have a PM.
Old 07-29-2017, 12:21 AM
z28jimmy's Avatar
Built 4L60. $800
LT1 oil tube $20
LT1 alternator $40
LT1 oil pump drive
cam sensor housing
New 1x cam reluctor
New 96-97 crank key
LS1 PCM bracket
LS1 0411 PCM
New 96-97 hub
How much for the complete 24x conversion kit? Is anything else needed to make it complete?
Old 08-11-2017, 02:26 PM
jj_macdragracing's Avatar
Default Lt1 parts
Im interested in alot of the parts u have listed.. i just pulled my lt1 stroker to freshen it and was looking to improve afew things.. is it all still available? ?
Old 08-11-2017, 10:09 PM
startingstock's Avatar
Default A/c
Do you have the a/c low pressure line with cap? The one you put the freon in? Price shipped to 33458?
Old 08-12-2017, 09:51 AM
MUSTANGBRKR02's Avatar
How much for the 24x stuff?
Old 08-15-2017, 11:45 AM
No response? ? You have pm's
Old 09-24-2017, 04:06 PM
mikeoguz's Avatar
PM'ed
Old 09-24-2017, 10:28 PM
94purplepearl's Avatar
pm sent hit me up motivated buyer
Old 10-17-2017, 07:59 AM
LS1Transam99's Avatar
do you still have the $50 water pump?
Old 10-21-2017, 04:27 PM
383z's Avatar
Hi everyone,
Sorry for the late response, but life was crazy with Houston flooding and a change in my job.
I didnt want to accept anyones money and not ship in a timely manner.
Let me know if you are still intrested in any parts.
Feel free to text or call. 713-922-7649.
Quick Reply: LT1 Performance & Stock Parts, 383, 24X, etc.
