Aero Space 3 Vane Vacuum Pump
Category: Accessories
Price: $300
Location (State): IN
Item Condition: Used
LS Engine?: Fits LS Engine
Pump:
Billet Aluminum Construction
Billet Aluminum Carrier for Low Rotational Mass
1 Piece Carrier/ Shaft Assembly for Zero Shaft Run Out
3 Carbon Fiber Vanes
Double Sealed Ball Bearings
O-Ring Sealed Cover
High Performance Shaft Seal
#12AN Inlet and Outlet Fittings
Correct Geometry for Maximum Vacuum
100% Made in U.S.A
Breather Tank:
Mounts With Two 1/4" Studs
12AN Inlet Fitting
Separates Air From Oil on Vacuum Systems
K&N Style Breather Element
100% Made in U.S.A.
