Race Weights?
Restricted User
Race Weights?
I am trying to get an idea of a typical race weight for a fourth gen. Looking for some input from the lighter guys...trying to find out how light you can make one.
-Dave
-Dave
You should really be looking at car weight because drivers can very over 100lb. My car can be as little as 3000lb(still complete w/ ac, cruise, all seats looks like a normal f-body) and I weigh 160.
Depends on what you want to do with the car. I have seen weights from 3600 to 2800 with driver. There is a lot of good info on here reguarding weight reduction if you spend lots of time searching and reading every post on the subject.
Currently my car is sitting at 2900 lbs without driver. I'm shooting for 2700-2750.
2680 last year 2850ish with driver. Since then switched to slick over radials, swapped the posi for a spool, ditched factory fans for slimfan. But also added n2o bottle and a fullsize battery in the rear.
Im 3006 with out me init with almost a full tank. Th400 9in ls1 strange brakes full tubular susp strange shocks pinto rack, billet specialtie wheels and a wolfe ms 6pt. I rewired the car from scratch and kept it all to a minium still have a 10in thunderform sub ozite carpet and corbeu seats... Ill be doin alot of cutting and welding overthe winter in creative ways and changing to a moly 10pt with moly sfcs and kirkeys and a bunch of lil things i just didnt wanna do so i could get back to track quickly
Im not sure where my weight is at but all that I have removed from the car will go towards my goal race weight of sub-3300lbs...that's with a iron block, turbo (a2w) and cage (8.50 for now but maybe a 25.5 in the future) I'd imagine a na/n2o setup can really get down there in the sub-3k lb range, good luck!
