Garage Cleanout: LS2, ZR1 Clutch Kit, LS7 Clutch, Slaves, Tick Master, etc
Sexy Party Mod
Category: Accessories
Price: $8675309
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
LS2 short block with 50K miles out of my 2007 Z51. This came as crossover year with a 58 tooth reluctor wheel and single bolt cam. Pulled for a lifter turning sideways and taking out the cam. It needs to be torn down. The lifter bore is a bit scuffed so a machine shop needs to look at it to give an opinion on whether it needs to be sleeved or just honed. The engine is pretty clean otherwise. Rather than having it fixed, I took the opportunity to go bigger and badder. The engine comes with a crate. $1000obo
scuffed bore
FREE SH*T WITH PURCHASE!!!
LS2 heads (243) SOLD
Factory LS2 Intake with injectors (no porting and no fuel rail) SOLD
Factory 90mm LS2 Throttle Body (no porting) SOLD
Lingenfelter ZR1 flywheel (6 bolt crank) and ZR1 twin disk clutch. The kit has about 3500 miles on it. Comes with bolts. $750
Stock ZR1 slave cylinder. 2500 miles. $100
Stock LS2/LS7 flywheel. 50k miles. $125
LS7 Clutch. New In Box. Opened only for inspection. $275
LS7 Slave. New In Box. Opened only for inspection. $175
Tick Master cylinder for C6 Corvette. 0 miles but installed in car. Needs a new threaded pushrod after someone (ahem) forced it down when a line was kinked. It can be fixed fairly easily but I just want it gone. The grease zerk is missing from the heim. It comes with the short braided line and all of the necessary hardware. $250
Dunno how this happened but I want to be as up-front as possible on this thing
C6 CAI + pre-cut Radiator Shroud. The thing is warped, needs to be cleaned and some TLC. Maybe someone can work their magic on it and make it right. $50
3 bolt Cam Gear- Free=$0. SOLD
LS2 Corvette Fuel Rail Covers-SOLD
Sexy Party Mod
All PM's have been replied and the I've received payment for the Throttle Body... It gone. The original post will be updated to reflect this shortly.
Sexy Party Mod
