MMS 220 Build for "Ghost Hawk"
Old 07-20-2015, 04:35 PM
Darth_V8r's Avatar
Received 1,852 Likes on 1,152 Posts
Default MMS 220 Build for "Ghost Hawk"
Well, I pulled the trigger on a build. I have two goals on this build:
---1. Get at or near 500 HP on stock 5.7 cubes N/A - Last Dyno 539/441 Jan 2018 -- RIP Feb 2018 due to excessive oil consumption
---2. Daily Drivability and reliability
---3. Numbers here: https://ls1tech.com/forums/generatio...l#post19482485 - post 481
So, here is the build list:
1. MMS220 heads - mamofied and fully assembled by the master himself
...1a. 2.055 hollow intake valves
...1b. AFR 8019 springs
...1c. Titanium retainers
2. 040 MLS head gaskets
3. Johnson short travel lifters with link bar --Replaced with LLSR solid lifters 6/16/2016
4. Manton custom length 11/32 x .125 pushrods
5. Yella Terra rockers with 10mm bolts
6. Fast 102 - mamofied - --Replaced with Mamofied MSD Airforce
7. Nick Williams 102 throttle
8. Maziere electric water pump
9. ATI underdrive pulley (long overdue)
10. ARP hardware
11. Lingenfelter 100mm MAF --Deleted and running SD with 4" silicone intake tubing
12. Cam will be the current cam in the car 227/236 112+3 --Replaced with 237/245-112.5+2 6/16/2016 with LLSR. After car warms up, actual profile at valves (minus lash) is 232/240-112.5+2.
Future upgrade paths to include:
...A. Light weight carbon clutch (31 lbs total weight)https://ls1tech.com/forums/manual-tr...ll-review.html
...B. Electric MR2 power steering pump--manual steering instead
...C. Kooks dual exhaust - Installed
...D. Mighty Mouse catch can - Installed
...E. GZ Motorsports Vacuum Pump - Installed
Already on car:
...I. 1-7/8" LT headers
...II. Monster S3 clutch - Removed and replaced with RPS BCS twin disc
...III. Tick Master Cylinder - 7/8" master replaced wtih 11/16" master
...IV. Bilstein shocks -- Viking DA coilovers -- Upgrade to Strano AFCO with UMI mounts, (motor overpowering chassis)
...V. 305/30/19 rear, 275/35/18 front - Now, not enough rubber!!--Replaced with Bogarts and 275/60/15 rear mickey's and 26x5x15 front runners
Chassis Upgrades:
...i. Fab nine inch rear from Burkhart Chassis - gear swap to 4.30
...ii. Torque arm, mount, and SFC also from Burkhart
...iii. Front spindle conversion to third gen (Burkhart) and strange brakes
...iv. Level 5 T56 from RPM Transmissions
...v. Carbon Fiber Driveshaft from Driveshaft Shop
...vi. Welded in the body seams
blsnelling (12-26-2019)
Old 07-20-2015, 05:03 PM
Darth_V8r's Avatar
I normally suck at documenting these things and then get mad when I didn't do it. Here's hoping the thread keeps me honest.
MMS 220's still in the box. Should have come in green and red wrapping paper
Top view. The first thing I noticed about these was the size of the pedestals and the lack of razor sharp edges around the surfaces. Yes, folks, you do NOT need a battle suit to handle these heads and avoid looking like you were mauled by a cougar. Note these are 2015 AFR castings, part number 1710
Plenty of room to exhale on these things
And also plenty of room to inhale. No breathing through a straw on these babies
Old 07-20-2015, 05:09 PM
Darth_V8r's Avatar
And more viewing material for your next one-handed trip to the bathroom (or wherever)
Here is where you really start to see the level of detail. I kept the camera low to show the whole port, and you can STILL see most of the intake valve. If I took the picture from the rafters of the cathedral, you can see almost all of it. Straight shot to the combustion chamber from the manifold
Here's a shot looking up at the roof so you can see the rocker boss on the right and how much contour went into the intake guides
Deck view.
One last shot to show the bowls There isn't a sharp transition anywhere. All nice and buttery smooth.
Old 07-20-2015, 05:11 PM
Darth_V8r's Avatar
So, once the lifters and rockers arrive, I'll be able to start the tear down and get the measurements for the pushrods and then start reassembly. Hopefully in the next week or two
Old 07-20-2015, 05:21 PM
Super Hulk Smash
JakeFusion's Avatar
Nice!
The Kooks duals are awesome btw. They are loud but you won't have a restriction with them.
Old 07-20-2015, 05:25 PM
MMorgan9812's Avatar
Very nice sub'd
Old 07-20-2015, 05:58 PM
mac62989's Avatar
LS1Tech 10 Year
Awesome. Ill be watching the progress
Old 07-20-2015, 06:28 PM
Ape Man's Avatar
Subscribed
Old 07-20-2015, 07:15 PM
mchdg86's Avatar
Very nice parts list and I am very much looking forward to the results. One question though. What made you go with such a large intake to exhaust split on the cam as Tony usually goes with a 4-6 degree split.
Old 07-20-2015, 08:00 PM
Darth_V8r's Avatar
Good question. I had three reasons. First, my exhaust isn't duals, and the merge pipe isn't the best so I wanted more duration to compensate. Second, I wanted to stay in the 227 range, because I tend to see that as the sweet spot. Diminishing returns above that point - you start giving up more for less gains. Third, I wanted the overlap to try to carry power past peak without giving up too much down low.
When I was picking it out, I couldn't decide between the tick SNS2 or the cam motion Titan 4. I knew I wanted to stay near 227, because I paid attention to Tony's builds. Kip split the difference on the valve events and this is what he arrived at. It's a great cam. Even on a BBK intake and mildly ported stock heads, it pulls very hard and carries to 6800 rpm. Has great partial throttle response
Hope that answers the question.
Old 07-20-2015, 08:17 PM
mchdg86's Avatar
Yes that absolutely answers my question and it's very hard to beat a 224-228 duration intake lobe on a 346 cube motor in a street application.
Old 07-20-2015, 08:52 PM
tmoney82's Avatar
sub'd
Old 07-21-2015, 07:54 AM
Rise of the Phoenix's Avatar
Very nice. Glad you got a build thread started. Looking forward to seeing how this combo stacks up.
Old 07-21-2015, 11:57 AM
Jake89's Avatar
Sounds like you are going to have one bad@$$ ride once this is all said and done. Subscribing to this.
Old 07-21-2015, 12:33 PM
So based on the second picture, they are AFR castings, but with a custom CNC port job that Tony created? Obviously his hand port work on your heads too, but you can see the "AFR" casted into the heads in that second picture.
Old 07-21-2015, 02:32 PM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
LS1Tech 10 Year
Awesome! Subscribing!
Could you share more info about the MR2 electric power steering?
Very interested about the potential to use for my C5.
Old 07-21-2015, 02:51 PM
Darth_V8r's Avatar
Yeah, Tony mentioned in his other thread that they are AFR castings. They carry a lifetime warranty, since they are AFR castings. What I can't answer to is if they are an off the shelf existing AFR like the 215 or if they are a proprietary casting Tony designed and has exclusive rights to, but contracts with AFR to do the actual castings. He will probably chime in on this thread eventually and if he does, he can answer that one.
I remember Tony making a comment about "out of the box MMS 220" vs mamofied, so I'm thinking they are a proprietary 220cc casting and the rest of it was the mamofication. You can't see from the pics as well as you can in person, but there were places the tooling didn't touch.
Old 07-21-2015, 02:54 PM
Darth_V8r's Avatar
The 1992 Toyota MR2 was a factory electric/hydraulic power steering system. small electric motor driving the pump (think Maziere-esque). With some custom hydraulic hose work, you can mate the MR2 pump to the rack and pinion and take the load off the crankshaft.
You could also use the 2013 Nissan Altima pump, but the servo motor they use makes this annoying whine. The MR2 was quiet.
Should free up more than the maziere water pump, since the fluid is more viscous and under higher pressure.
Old 07-21-2015, 03:36 PM
Super Hulk Smash
JakeFusion's Avatar
Turn One pumps also free up HP... I think like 7HP. Or you could just goto a manual rack and build your guns.
Old 07-21-2015, 06:13 PM
Darth_V8r's Avatar
I didn't know that. If a better engine driven pump is worth 7, how much is the entire load worth? Close to 20?
Quick Reply: MMS 220 Build for "Ghost Hawk"
