Petro's ERL Superdeck 427 w/ Whipple 2.9L
Old 03-16-2016, 10:46 PM
Petraszewsky's Avatar
Default Petro's ERL Superdeck 427 w/ Whipple 2.9L
Here's where I'll start at with the new setup:
The Triple Pillar Gauge Pods that are sold for us 98+ guys are a horrible fit and don't snap into place like the factory piece. This build/write up can also apply to single or double pod installs I just used the triple pillar pod. I started off by doing a rough measurement of where to cut the aftermarket pod so that it would fit onto the factory one. Then after making my first cut I did another test fit to make sure it would all line up inside in cab and marked on the factory piece how far up the aftermarket one needed to be. This was only a rough fit and I didn't want to trim too much off. I waited to any more trimming until after I had bonded the pieces together.
You can see how the two piece are different
Aftermarket piece does not have this part on it:
Fitted together:
I used JB Weld Plastic Weld to bond the two pieces together. The 3M Bumper Repair Kit Part # 280 is for blending to two pieces together later on. First off I scuffed/sanded all the areas that would be bonded together with 60grit sand paper and cleaned with mineral spirits afterwards.
Then I held the two pieces together and roughly marked how far up I needed to put the JB Weld Plastic Weld on the aftermarket piece.
Then I followed the directions on the JB Weld and pressed it onto the aftermarket piece and clamped the two pieces together. I let it sit overnight and the next morning I couldn't pull the two pieces apart. Satisfied that they weren't coming apart I test fit them in the truck again made my final trim of were the aftermarket piece overhang off the factory one.
Now it's time for the 3M Bumper Repair Kit to blend the two pieces together. This stuff is great! It's semi-rigid, flexible, and sandable just like a molded ABS part. It's easy to work with and cures solid in like 3-4 hours. Plus along with blending the two pieces together it also helps bond them even further.
You can see the gap on the other side and how well the 3M fills it in.
Next I will be trying to replicate the factory grain with some graining pads and Viper Clear Tex. Then finally spray it to match the factory color with some SEM Color Coat spray.
Old 03-16-2016, 10:47 PM
First off I sanded the entire thing with 150 grit to get the shiny texture pattern off then I went over it with 320 grit to get the 150 grit marks off of it since the texture coat doesn't hide imperfections. So with it all nice and smooth and wiped down with mineral spirits I started applying the texture coat. I let it sit for a few minutes then pressed the crumbled wax paper onto it making sure to gently press it on all over the area I was working on. Satisfied that it was all pressed down I would then rip it off like a band aid and begin work on the next small area. You can press it on and rip it off where the previous area and new area meet to help blend it together.
Once the texture coating dried I hit up with 400 grit to level and smooth it out.
I lightly wiped down with mineral spirits again to get rid of the little bit of sanding dust from the 400 grit. Then I sprayed light coats of the SEM Color Coat.
Old 03-16-2016, 10:48 PM
Finally got a Envoy Bumper Cover and Factory Envoy Headlights w/ real HIDs (actual ignitors and bulbs)
These are the ballasts for the OEM HID Envoy Edition lights. They are at least 15 years old and have lots of oxidization built up along with dirt etc embedded in them. FYI they were $1000 new from GM when they still mad them as they are a special GM only design. When these fail I'll retrofit the Envoy headlight assembly with a aftermarket D1S kit. Took some time and cleaned one up. I plan on everything being clean like new when I put the truck back together this go around. I had to use Rust Remover Gel and let it sit for 2 hours to get the oxidization off.
Got a few more parts in recently...Nothing crazy just Billet for the upper grill and for the Envoy edition bumper, New Fog lights , DEI Cool Tube, Tiny 35lb strength magnet, and loaded BCM. The TRZ control arms are going to take about 3 weeks or so to build since I ordered the lowers with slightly thicker walls...I could've gotten the engine done by ERL to be a 440 but knew it didn't make sense to get the engine finished up when I have so much more left that I want to do to the truck...
Hopefully some more goodness will coming as the summer progresses. (Frame painted, Mock up complete SS exhaust, Wilwood Superlite Brakes, Wheels,Tires,.....)
Got the bed off (I pressure washed it after this pic)
And I ordered these AFCO Sliders today too!
Old 03-16-2016, 10:49 PM
Here's the TRZ control arms and the Afco sliders. I got the double gusset and thicker walls on the lowers since I will be driving it on the street when finished. I'm not sure what brand of ball joints come with the TRZ arms but I have some basically new Afco low friction ball joints on the stock A-arms right now so I'll keep those for future use. My leaf springs are Cal-Vert Split Mono Leafs and they use Chrysler size bushings so I had to order the Afco sliders to accept the Chrysler bushings.
Got these in the mail yesterday the quality looks to be nice. Heavy as hell but no biggie like I said before I plan on having a set of some Weld RTS wheels for the dragstrip. The front fenders are sitting way up in outer space but they will be tucking the front tires just a little bit when it's all done. Same with the rear wheels they'll be tucking just a bit also. And all of this will look better when the 13-14" Wilwood brakes arrive
The 11.6" rotor in the rear looks tiny behind the 20" wheel
And here is the build sheet. Billet Main caps are also included but not listed with the ARP main cap studs. The Wiseco pistons are shelf part number K452X12de for racing and they are -20cc dished pistons with valve reliefs to fit LS1,6,2,3,7,92 valves. I can't afford the Callies Dragonslayer Crank and Rods they add a hefty amount to the build. I am confident the Callies Compstar Crank and Rods will be enough for the tiny amount of power I'll be making.
The cab was a bit more of a beast to get off than expected and required some collective thoughts and inputs and redneck engineering. My design for the stand with casters wasn't the best but it works. (While getting it in the garage with my wife I was lifting while she pushed and the caster got sideways like Mike had warned about and that corner collapsed crushing my hand between the body and the block of 2x4s I built. Needless to say if she wasn't there to kick and kick and kick the block out while I desperately tried to lift to get my hand uncrushed it could've have been a bad day.) So a BIG thanks to my wife and a life lesson learned. Anyways I'm about a week out from the fabrication work on the frame etc. Looking forward to some more progress. I'm hoping I'll have enough money to have it blasted and coated by the time the new engine arrives. Time will tell and I'm not in a big rush.
Just a update cause I'm excited about dropping the frame off today to have some major surgery done to it.
New shock bar to make shocks 90*
Afco sliders installed
Reinforcement bar at the rear welded in
Front crossmember redone to look and perform better
Notches cut and boxed in for the axle
Front spring eyelets raised 1" to drop the truck without using a tall drop block
V-bands welded onto headers
Few other little odds and ends too
Old 03-16-2016, 10:51 PM
I got asked if I a could polish a cast aluminum turbo compressor housing and since I've never attempted a rough sand cast piece before I didn't feel super confident. I asked if he had a old one laying around I could test out but he didn't. So today I remembered the LS2 Vette oil pan I have is rough sand cast so I started going at it. As always still a ways to go but the process wasn't horrible to remove the super rough casting marks and this project will help make me a bit comfortable polishing his piece.
While I was at it I cut off the protective shroud piece where the low oil sensor would go. Since I don't need that sensor and that piece has very little clearance to the frame it went bye bye. (Maybe some cool hot rod part could take the threaded hole's place instead of just a plug)
Before:
After rough cut:
Then some more pics
The engine came in today!
It's just a little 5.3L
[URL=http://s1377.photobucket.com/user/LSXSONOMA/media/IMG_3937_zpsay9z6uok.jpg.html]Name:  IMG_3937_zpsay9z6uok.jpg
Old 03-16-2016, 10:52 PM
TRZ makes nice products and I'm just as impressed by their billet anti roll bar as I am with their control arms.
Just placed a pre-order a Improved Racing 4" stroke crank scraper kit. They are currently revising the design complete with new windage tray. Pre-order now and save before the price increase!
Possible gain of up to 2% HP increase at the wheels! I'll take 15 extra RWHP for $70!
Old 03-16-2016, 10:53 PM
A Ford piece may actually find it's way onto the truck
Driveshaft Safety Loop 99-04 Mustangs Mach1, GT or Cobra
A guy over on S10Forum used this on his build and to me it's a nice clean functional install that's easy enough to bolt on and remove if necessary.
This is the cam Vengeance Racing specd for me after I completed their thorough custom cam spec sheet. Fingers cross it'll help get me to 950-1000 HP at the crank. Ron is a ex Army Ranger so I like supporting his business even though he has plenty as is and I've purchased from VR before.
23x/24x .6xx/.6xx 118+5
These wheels are badass: WEDGE | Billet Specialties, Inc. (they discontinued my SLG20s shortly after I had them made)
Old 03-16-2016, 10:54 PM
Old 03-16-2016, 10:55 PM
Unfortunately the guy that owned and operated hoodliners.blogspot.com passed away after a long struggle with cancer. So I found a place that sells the product similar to what he used for his hoodliners. Just ordered some and I will be doing a test fit on the spare hood I have to see how good it turns out with me doing it.
Link to hoodliners: Aircraft firewall material hood liner insulation pad for Mustang, Corvette, Jaguar, many other cars: Ford-Lincoln-Mercury Hoodliner Gallery
Link to wicksaircraft: Item # SP-250, Soundproofing Foam On Wicks Aircraft Supply
Old 03-16-2016, 10:56 PM
I think this will flow some exhaust gases well!!! It also looks like it will fit the header collectors with ease and barely any modification. I flipped the x pipe and put the front short pipes on and came up with slightly more than 20" center to center (When I mocked the headers up on the engine I got 20 1/4" center to center and 17" inside to inside). Weighed the whole thing and it came it at less than 15lbs!
Looking from one end of the x-pipe to the front short pipe
The X pipe has a arrow on it which I'm guessing is supposed to the flow direction through it but with it that way the center to center on the front short pipes is 21 3/4". Looking at the x pipe I don't see how flipping it to flow opposite the direction of the arrow could affect it greatly. What do you guys think?
Got the solid mounts and another transmission crossmember. The one on the left is for the 4L65E I currently have and the other is for a 4L80E (with 6 speed conversion) if I bust the 65E. The exhaust will be mocked up to fit both transmissions without any future modifications.
I don't want the fuel tank to have straps holding it up and showing which can't be done with aluminum so stainless is the way it'll be going and have a floating in space clean look to it:
I also got this for when it's time to get the engine pre lubed
Pre-Lube Tank
Pre-Lube Engine Oiler Tank by Melling®. The newest addition to Melling’s offering is a pre-lube tank. This design is necessary because of the inability to prime the oiling system in today’s modern engine with the oil pump mounted over the crankshaft. We did not need this in older engines because you could use the tools provided by Melling and a common drill to turn the pump and prime the system.
Old 03-16-2016, 10:57 PM
I spoke with Casey Wegner with Wegner Motorsports and he sent me some CAD drawings with measurements. It's looking like it will be a snug fit with the steering box. Hopefully this will be a March purchase as long as the cardboard mock up fits. First is the garage lift/fuel tank/cam. Chugging right along
I like this setup over the Concept One setup not only for better looks but also for the dedicated supercharger drive belt.
I got antsy and did a quick loose test fit today of the exhaust and it looks like it going to fit like a glove! A nice smooth seamless customizable mandrel bent exhaust that will be sectioned off with v-bands. One idea I will using is for a v band after the x pipe section for the mufflers. Thinking forward enough to measure accordingly so that if I dislike the mufflers it will be easy enough to replace with a different one. For instance a 14" muffler vs 18" muffler. I'm thinking to have the exhaust exit in front of the rear tire and have a tip flush mounted and frenched into the stepside.
These headers were designed around 4L80Es so with this 65E a little bit of shaving will need to be done on the bellhousing. Just ever so slightly.
Should be good with a 4L80E as they are basically the same overall length as the 65E. (65E=31 5/8" 80E=31 7/8") Will still test fit with 80E just to make sure everything clears both transmissions well.
With the tips coming out something like this:
June 30th:
On another note does anyone know of any companies that can make custom steering wheel airbag covers? I'm wanting to get the Sonoma script embossed into the cover without the GMC or Chevy logo on it:
October 27th:
On a episode of Bitchin Rides they recovered a steering wheel airbag with leather and had successful deployment of the bag. So maybe I'll give Kindig It Designs a call.
I also have the idea of transplanting the interior harness out of a Bravada or Envoy edition along with the BCM so that I can use the Computer Climate Control Unit among other things like integrating some type of Electronic Traction Control. Just brainstorming ideas and throwing it out there.
Today:
Another small update: I spoke with Justin at JS Custom Interiors and he mentioned laser etching the leather on the steering wheel airbag cover instead of debossing it. So I'll have it redone in matching OEM grain leather and then the Sonoma GT script (minus the letters GT) etched into it. Hopefully it adds a small touch that looks OEM but is custom. That's the look I want for the whole truck actually.
Old 03-16-2016, 11:02 PM
Got a couple new things for Christmas. Nothing big just tiny parts
-ARP SS Bellhousing bolts
-Black poly engine mount inserts (I had red but want to match the black ES trans mount haha)
-Lug Nuts
-Lug nut sockets
-Tools
-Fumoto Oil Drain Valve (because of the location of the oil drain bolt when you drain the oil it gets all over the crossmember. With this valve I won't have messes.)
-Percy's SS locking header bolts
Old 03-16-2016, 11:03 PM
Getting the engine and trans in with no cab is so much easier! The P/S Pump and pulley are going to fit easily but the reservoir will probably have to be remote mount no biggie there. I'm sure I can find somewhere to tuck it away out of sight.
Quick Reply: Petro's ERL Superdeck 427 w/ Whipple 2.9L
