New GM TTY head bolts, GM valve seals and NNBS Parts
Category: Accessories
Price: $50
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NV
Item Condition: Brand New
LS Engine?: Fits LS Engine
Selling a New set (x2) of GM TTY Head bolts for 2004+ engines with equal length bolts. These head bolts will do both heads. GM # 17800568 (x2)
**Price for GM TTY head bolts (50.00 Shipped) using USPS Priority Flat Rate.**
Selling a new set of GM Exhaust Valve Seals/Locators, includes 8 exhaust seals. GM # 12482062. These fit all cathedral port heads including 97+ 4.8, 5.3, LS1, LS2, LS6 and a few more.
**Price for GM Exhaust valve Seal kit (20.00 Shipped) using USPS Priority Flat Rate.**
Selling a New 4L60E/4L65E/4L70E Low and Reverse Clutch Piston, GM # 8685549 (Casting # 8685550-32). This is the newest and strongest OEM piston for the 4L60/65/70E trans. Previous castings tended to crack.
**Price for GM Low & Reverse Clutch Piston (40.00 Shipped) using UPS ground.**
Selling two lower strut coil spring insulators for NNBS Trucks 2007.5-2013, GM # 15808594. This is the white plastic piece that goes between the coil and lower metal strut plate to prevent metal to metal contact.
**Price for GM Strut Insulators (25.00 Shipped) using USPS Flat Rate.**
Selling a used On-Star Module, this does not have Bluetooth. This will fit 2007.5-2009 NNBS trucks and other vehicles from 2007-2009. GM #25911919 (25826499). Retail new is 225.00. Module is in great working order and will need to be programmed to work with your vehicle. I Switched over to a Bluetooth unit.
**Price for used GM On-Star Module (25.00 Shipped) using USPS Flat Rate.**
Free On-Star Antenna for 2007.5-2009 NNBS trucks, it is used. This is for On-Star only and does not have the plugs for XM. GM # 20850446. Part is in great shape and worked great. Switched over to the XM Style. Retail new is around 55.00.
**This part is free, just pay shipping of 10.00.**
Everything but the Cams price is including shipping cost using USPS Flat Rate to anyone in the lower 48 states. This seems to be the cheapest route I can find at the moment. Will check each store after Memorial Day.
**Prices are firm and the best I can do with Shipping.**
GM Head Gaskets (x2) 50.00 Shipped
GM TTY Head Bolt kit (x2) 50.00 Shipped
GM Exhaust Valve Seal/Locator kit (x8) 20.00 Shipped
GM Head Gaskets (x2) and GM TTY Head Bolt Kit (x2) 80.00 Shipped
GM Head Gaskets (x2), GM TTY Head Bolt Kit (x2), GM Exhaust Valve Sea/Locatorl kit 100.00 Shipped
