BMW + 427ci 7.0l + full-on build
Old 05-27-2017, 08:26 PM
MUL8NO1's Avatar
Default BMW + 427ci 7.0l + full-on build
Greetings to my post - I'm sharing largely because I chose to be an early adopter of a new product specific to Making an LS live.
I purchased the first #70013 Kit from Jegs last Thurs... I received it 1.5 days later - out of box 10min after I saw box on porch - two hours later the Intake Manifold had all sensors, throttle body, Inj / Fuel Rail Etc. I weighed each Component because others may care to know such details.
This would be the very first time I've allowed myself to be an early adopter of new Tech of any kind.
The kit is already sitting on engine along with full wiring harness laying where necessary to get to the Plug part of the Play!
Fresh LS2-based bottom end.
Fresh LS3/based heads.
Pat G custom cam
Etc
(THIS MOTOR DESCRIBED ABOVE IS NOW DEAD-Jan’18-AND IS NOW THE 7.0l as described in Title Name Change)
BMW road race chassis, Full new build
The chassis / suspension / brakes/ et al are ready for this car to start. The decision to go FiTech was NOT an easy one as 'tried and true' has inherently less risk. Anyway, on to pics for your enjoyment and/or amusement!!!
Attached Thumbnails BMW + 427ci 7.0l + full-on build-img_3403.jpg   BMW + 427ci 7.0l + full-on build-img_3404.jpg   BMW + 427ci 7.0l + full-on build-img_3400.jpg   BMW + 427ci 7.0l + full-on build-img_3359.jpg   BMW + 427ci 7.0l + full-on build-img_3226.jpg
BMW + 427ci 7.0l + full-on build-img_3212.jpg   BMW + 427ci 7.0l + full-on build-img_2995.jpg   BMW + 427ci 7.0l + full-on build-img_2987.jpg   BMW + 427ci 7.0l + full-on build-img_2861.jpg   BMW + 427ci 7.0l + full-on build-img_2297.jpg
BMW + 427ci 7.0l + full-on build-img_2290.jpg   BMW + 427ci 7.0l + full-on build-img_2287.jpg   BMW + 427ci 7.0l + full-on build-img_2304.jpg
Old 05-27-2017, 08:35 PM
MUL8NO1's Avatar
Default More build pics
Mas pics of build details
Attached Thumbnails BMW + 427ci 7.0l + full-on build-img_2016.jpg   BMW + 427ci 7.0l + full-on build-img_1980.jpg   BMW + 427ci 7.0l + full-on build-img_1986.jpg   BMW + 427ci 7.0l + full-on build-img_1991.jpg
Old 05-28-2017, 10:18 AM
Jimbo1367's Avatar
LS1Tech 10 Year
What are your thoughts of the intake manifold? Does it look like a rebaged Holley Sniper manifold?
Old 05-28-2017, 04:00 PM
MUL8NO1's Avatar
As for thoughts on Manifold, I have been all over this FiTech version trying to find indicators of similarity to other sheeetmetal intakes... and TB too... I'm not finding telltale details yet.
That said, I've got no problem taking investigative pics to share so we can figure it out as a whole - the closest pairing so far is the from The sheet metal Intake from where TSP compared against LS3, Fast, etc on their own test, like this one (but LS3 version)
Look at this on eBay:
https://www.ebay.com/itm/262811094512
102mm LS1 LS2 SHEET METAL INTAKE FABRICATED TIG WELDED ALUMINUM W/FUEL RAILS
Attached Thumbnails BMW + 427ci 7.0l + full-on build-img_3360.jpg   BMW + 427ci 7.0l + full-on build-img_3361.jpg   BMW + 427ci 7.0l + full-on build-img_3389.jpg   BMW + 427ci 7.0l + full-on build-img_3390.jpg   BMW + 427ci 7.0l + full-on build-img_3402.jpg
Old 06-03-2017, 04:58 PM
98blackbirdta's Avatar
I'm right behind you. Had a customer come in for some Ls swap clean up on his impala and I brought up this kit due to his budget. Ours should be here Monday.
Old 06-03-2017, 11:41 PM
MUL8NO1's Avatar
Default Possible FiTech throttle body match
'New' throttle body from large online retailer sure looks much like my FiTech unit:
Jegs
I'll get pics up in a bit
Attached Thumbnails BMW + 427ci 7.0l + full-on build-img_3675.png   BMW + 427ci 7.0l + full-on build-img_3367.jpg   BMW + 427ci 7.0l + full-on build-img_3416.jpg   BMW + 427ci 7.0l + full-on build-img_3678.jpg   BMW + 427ci 7.0l + full-on build-img_3679.jpg
BMW + 427ci 7.0l + full-on build-img_3680.jpg   BMW + 427ci 7.0l + full-on build-img_3465.jpg   BMW + 427ci 7.0l + full-on build-img_3466.jpg
Old 06-07-2017, 06:16 AM
Mungface78's Avatar
Doe's it come with any software beside's what's included with the handheld?
Old 06-07-2017, 07:57 AM
MUL8NO1's Avatar
Default No additional software in box
There was only hardware in Ultimate LS box / packaging.
I've been on pause to continue with install due to decision to add more go faster/better/safer parts on/in engine - and those parts will all be here by tomorrow... which could lead to a solid weekend effort to make real progress - which leads to a better update!
As for software, I'll certainly be figuring out what's what and then sharing!
Old 06-07-2017, 01:01 PM
DW SD's Avatar
Very awesome project!
Old 06-18-2017, 07:08 PM
Buddy z/28's Avatar
Does the manifold have tap bolt holes for throttle cable
Old 06-28-2017, 01:28 PM
Sube's Avatar
Any updates?
Old 07-07-2017, 08:50 AM
gagliano7's Avatar
Any updates?
Old 07-07-2017, 08:06 PM
MUL8NO1's Avatar
Default Kid Delay and more parts purchase/install
Originally Posted by gagliano7
Any updates?
New Fancy crank/cam Adj gears C5R Z-Chain, New GMPP higher flow/volume oil pump, New Timing Cover 2-piece, new crank damper, etc
Old 07-07-2017, 08:14 PM
MUL8NO1's Avatar
Default And needed New TSP Steel Roller Rockers / Pushrods Measure etc
Originally Posted by Sube
Any updates?
I'm still deciding on Pushrod length. Yes, I'm using the Comp Cam PR Adj tool... and I've got two sets of PR in 2 different lengths - the shorter of the two Pushrods which TSP recommended appear to just be too short - and my longer ones appear to be just too long (based on number of turns issue with rocker bolt. The wipe pattern on top of valve appears to be 'okay' with either PR... so deciding on that factor alone is proving insufficient.
Old 07-07-2017, 08:26 PM
MUL8NO1's Avatar
Default Oh and the O2 sensors installed
The Fitech provided dual wideband O2's installed. I still need to install the Lingenfelter Oil Cooler adapter thingy just above the oil filter location - I'll get that this weekend!
Old 07-07-2017, 08:55 PM
Mungface78's Avatar
That is going to be a super fun car!
Old 07-07-2017, 10:08 PM
MUL8NO1's Avatar
Default In the back...
Nothing short changed on this one...
Old 09-24-2017, 07:32 AM
MUL8NO1's Avatar
Default The band is back together
Halo shot
Clean, all turns over nicely with Apr crank bolt being rotated.
Different details here and there
Just a wrap but adds to the overall effort
This look is.... not bad / at all!
Beefy
Welp that'll easily fit under hood. I'm not concerned with loosing torque with this type of intake Manifold... vehicle is 2500lbs. I'll still get 400rwtq and may get to 500rwhp... making the overall combo slightly greater than 5:1 hp/wt from the crank.
Progressive... impressive to look at and day dream how it performs - it's much closer, but still to go:
3 fuel run
wiring
throttle linkage
battery
vacuum lines
pwr steering
etc
Old 09-24-2017, 11:35 AM
Jimbo1367's Avatar
LS1Tech 10 Year
Does your son realize he's sitting in his x-mas present? LOL
Old 09-24-2017, 12:41 PM
MUL8NO1's Avatar
Default The learning curve
My daughter, 6yrs old this coming Tuesday, is heir to the driver's seat - as she's worked thru push scooter, e-scooter, bike w/out training wheels (years back), and negotiates obstacles (cones, bumps, cracks, brother) consistent with someone that actually is getting ready to drive this car. Daddy has a M Powered version of this car already... that'll be the 'training wheels again' when the time is right (dunno, 10yrs old too early?)..! Sissy already has a car that she's been restoring / modifying with Daddy... vision, creation, smart efforting, teamwork, more - all healthfully developed in a car build
Quick Reply: BMW + 427ci 7.0l + full-on build
