Loud backfire when starting now engine locked up??
Old 06-21-2017, 07:03 AM
80/TA/LT1's Avatar
Default Loud backfire when starting now engine locked up??
Well, I've never seen this happen, but last night I went to start my turbo 5.3 which was running fine and it backfired really loud through the intake and wouldn't turn over anymore. I hoped it was a starter/ flywheel issue but it wasn't. I could turn the crank with a breaker bar but only counterclockwise, when I turned it back clockwise it kept getting stuck in the same spot. Is it possible I bent a rod just from that single backfire?? I didn't check it out any further yet cuz I'm so 😡, ugh, il probly pull the plugs tonight, really didn't think a pop when starting would screw me this bad, figured it would happen when I was beating the nuts off it, any insight is appreciated thx guys
Old 06-21-2017, 07:21 AM
671blownlsx's Avatar
Ya pull plugs then try and rotate..
Old 06-21-2017, 07:25 AM
80/TA/LT1's Avatar
What else do you think it could be? Broken plug in the cylinder? Or bent valve? I'm at a loss right now, there was no strain on the motor, sounds like major damage from a backfire, although it was loud, like a 9mm going of...
Old 06-21-2017, 07:44 AM
I would be surprised if so..do you have electric fuel pump..maybe you filled cylinder with fuel and locked it..
Have to pull plugs see what comes out then if nothing remove valve covers check push rods
Old 06-21-2017, 08:02 AM
Old Geezer's Avatar
Broken crank............
Old 06-21-2017, 08:03 AM
80/TA/LT1's Avatar
Yea walbro 450, ok gonna look now
Old 06-21-2017, 08:07 AM
KCS
KCS's Avatar
Not enough info to really say for sure, it could be almost anything.
Chances are, you're going to have to pull the engine and rebuild because it sounds like there's some serious internal damage, but you could narrow it down before you pull it. I would start with the plugs and see what they look like. Usually a ground strap will be closed up for damaged on the cylinder(s) that had something failed.
You could also pull the valvecovers and look for any dropped or stock valves, broken valvesepings, etc.
Old 06-21-2017, 08:14 AM
Don't pull unless needed check easy stuff first
Old 06-21-2017, 08:16 AM
80/TA/LT1's Avatar
Well number 8 cylinder poured gas out, sticky injector? More to come only two plugs out.....
Old 06-21-2017, 08:30 AM
80/TA/LT1's Avatar
Ok cyl 8 was loaded with fuel all plugs are out and the motor turns, I'm gonna spin it to empty the cylinder, put plugs back in cross my fingers and hope all is well
Old 06-21-2017, 08:48 AM
You be ok mostly likely..change oil too because oil pan is probably got gas in it to..
Old 06-21-2017, 08:50 AM
don't want to keep cranking a fuel injected motor you'll fill your cylinders up with fuel every time you crank it and it doesn't start it's just loading it up
Old 06-21-2017, 09:14 AM
RockinWs6's Avatar
All is well? If that cylinder was full of fuel you at least have a bad injector. Stop and at least pull the injectors, spin the engine over and check compression.
80/TA/LT1's Avatar
I pulled the fuel pump relay
Old 06-21-2017, 04:29 PM
KCS
KCS's Avatar
Hopefully it didn't hydrolock the cylinder.
Old 06-22-2017, 01:18 PM
80/TA/LT1's Avatar
checked compression in cyl 8, its 140, gonna order a new injector tonight
Old 06-22-2017, 01:23 PM
Old Geezer's Avatar
Exclamation Do them..
All. Not just the 1 you think is hung up.
Old 07-10-2017, 04:56 AM
80/TA/LT1's Avatar
Well, compression checked ok. Aired out the cylinders a couple days. Replaced #8 injector, started it and it's knocking, man wtf ??? I really can't believe this ****... I'm gonna pull the valve covers to take a peek, but I'm pretty sure it's a rod, fml.....
Old 07-10-2017, 06:50 AM
Floader's Avatar
I have seen two motors break rods on start up because the injectors stuck. One we pulled the head and pan and put a new rod/piston in that hole..... the other one window'ed the block. I have taken to pulling the fuel rail off of these junk yard swaps with the injectors attached to make damn sure none are leaking.
Old 07-10-2017, 09:02 PM
NHRAFORMULA00's Avatar
dont start it anymore, it has a bent rod
Quick Reply: Loud backfire when starting now engine locked up??
