Oil Pressure Switch replacement - now high pressure readings
Old 07-05-2017, 06:40 AM
bleepster's Avatar
Default Oil Pressure Switch replacement - now high pressure readings
replacing the AC compressor on a 2002 bird with the V6 and we accidentally broke the oil pressure switch. broke it where the plastic meets the metal body. see attached pic.
replaced it with a new Duralast Oil Pressure Switch and the pressure reads 95-100 cold start and even when at operating temp.
before change it would read 70 at cold start and run close to 55-60 at operating temp.
think I just got a bad switch? should I replace it? is it safe to drive?
appreciate any insight.
thanks
Old 07-05-2017, 07:48 AM
smitty2919's Avatar
Verify with mechanical gauge. Then determine if current switch is bad.
Old 07-05-2017, 08:00 AM
bleepster's Avatar
^^ I'll borrow one to verify. OK to drive if needed? or best to wait?
Old 07-05-2017, 08:03 AM
smitty2919's Avatar
If it was OK before, then I ASSUME you would be fine to drive. But be aware you are driving without a proper reading. Drive at your own risk.
Old 07-05-2017, 08:04 AM
bleepster's Avatar
understood - thanks
Old 07-05-2017, 08:06 AM
smitty2919's Avatar
Pick up a cheap pressure gauge from Harbor freight. It comes with assorted brass fittings of different sizes. It's always good to have one on hand as a diagnostic tool.
Also get a mechanical fuel pressure gauge. Both can be had for around $30 each.
I bought these:
https://www.harborfreight.com/engine...kit-62621.html
http://www.autozone.com/test-scan-an...ter/273356_0_0
Old 07-05-2017, 08:08 AM
bleepster's Avatar
LOL - i just got off harbor freights web-site - $25 for a gauge for oil pressure with tons of fittings
Old 07-05-2017, 08:11 AM
smitty2919's Avatar
Not 100% about a V6, but MOST sensors will be 1/8" NPT. The end of the oil pressure gauge I believe has a male 1/8" NPT crimped on the the rubber line. So you can simply screw it into the block.
Old 07-05-2017, 12:38 PM
Spartan7's Avatar
Originally Posted by bleepster
replaced it with a new Duralast Oil Pressure Switch...
That's your problem. Duralast make the worst sensors. Buy an AC Delco.
Old 07-05-2017, 12:40 PM
bleepster's Avatar
4th of July - Autozone - limited options. I will still check mechanically and O'riellys has an AC Delco - a bit more but I am sure worth it
Old 07-05-2017, 12:41 PM
pdxmotorhead's Avatar
I went through 3 on my jeep recently 3 different brands the 4th sensor was good.. Thought it was a fluke then had a DOA replacment one on my Honda..
Old 07-06-2017, 06:09 AM
Save the manuals!
wssix99's Avatar
These are notorious for being bad out of the box. I went through the same issue a while back. Things are much better with the AC Delco sensor.
Old 07-06-2017, 06:34 AM
bleepster's Avatar
Thanks wssix99. I appreciate all the replies.
Old 07-06-2017, 08:27 PM
farmington's Avatar
Rock auto
Old 07-06-2017, 10:08 PM
Save the manuals!
wssix99's Avatar
I'm surprised you seem to have survived the experience so wonderfully. I totally sliced my arms up on the screws sticking down from the cowl. It looked like I stuck my arms down a garbage disposal. This part is not a fun one to replace... https://ls1tech.com/forums/general-m...ding-unit.html
I'm sorry you have to do it again.
Old 07-07-2017, 08:11 AM
bleepster's Avatar
dont forget I have the V6 - the Oil Pressure Sensor/Switch is right above the oil filter and sticks out like a sore thumb. Part #7 on the diagram
Old 07-07-2017, 11:55 AM
Save the manuals!
wssix99's Avatar
That's so unfair...
Old 07-10-2017, 07:23 AM
bleepster's Avatar
swapped out the OPS and now readings are back to where they were
**SOLVED**
Quick Reply: Oil Pressure Switch replacement - now high pressure readings
