Oil Pressure Switch replacement - now high pressure readings
replacing the AC compressor on a 2002 bird with the V6 and we accidentally broke the oil pressure switch. broke it where the plastic meets the metal body. see attached pic.
replaced it with a new Duralast Oil Pressure Switch and the pressure reads 95-100 cold start and even when at operating temp.
before change it would read 70 at cold start and run close to 55-60 at operating temp.
think I just got a bad switch? should I replace it? is it safe to drive?
appreciate any insight.
thanks
thanks
Pick up a cheap pressure gauge from Harbor freight. It comes with assorted brass fittings of different sizes. It's always good to have one on hand as a diagnostic tool.
Also get a mechanical fuel pressure gauge. Both can be had for around $30 each.
I bought these:
https://www.harborfreight.com/engine...kit-62621.html
http://www.autozone.com/test-scan-an...ter/273356_0_0
I bought these:
Not 100% about a V6, but MOST sensors will be 1/8" NPT. The end of the oil pressure gauge I believe has a male 1/8" NPT crimped on the the rubber line. So you can simply screw it into the block.
Save the manuals!
I'm surprised you seem to have survived the experience so wonderfully. I totally sliced my arms up on the screws sticking down from the cowl. It looked like I stuck my arms down a garbage disposal. This part is not a fun one to replace... https://ls1tech.com/forums/general-m...ding-unit.html
I'm sorry you have to do it again.
