How to go speed density?
I've been searching but haven't found a "how to".
Anyone know where I can find a write up or video on how to make my car go speed density? I'm getting rid of the MAF all together.
my car is just a H/C/I build, nothing crazy.
Also is this is the correct sensor I am going to need?
You didn't mention the pcm you are using but generally you just set the MAF fail frequency to zero and it will revert to the VE table. It will set a code and light the SES, then go set those to not report.
I'm not going to click the amazon link, but most guys just go to a thread in IAT and stick it in the intake somewhere.
This post should be in the pcm diagnostics and tuning area. You didn't mention the pcm you are using but generally you just set the MAF fail frequency to zero and it will revert to the VE table. It will set a code and light the SES, then go set those to not report.
more specifically how do I hardwire it in? I will get it tuned once I get it all together, I just am not exactl sure what sensor to get and how to wire. Or if it is more involved than that
thanks guys.
Ok I clicked the link. If you have a 5 wire maf then yes the IAT you linked will work. Just wire it in to the 2 wires that originally went to the 5 wire maf for the IAT portion and cut the other 3 wires out.
It's exactly what I did on the Stude and will be doing again on the nova I'm building.
so I don't need an IAT sensor in the lid?
thanks
But Im boosted now and at the max the computer can do on the 2 bar SD tune. Im swapping in a p59 pcm so I can run flex and a 3 bar SD tune and getting my harness rewired for it. So I will have a spare 98 pcm for sale if your interested.
If its a 98 you have an MAF pigtail and a IAT pigtail. I have a 98 and went to a speed density tune from Pat G for a H/C/I Th400 (they swap it over to m6 tune file).
So I am assuming I just reuse the pigtail and sensor from my current SLP lid and put it into my FTP 92MM lid and call it good?
That's all I need to do correct?
I just want to make sure I get everything right before I get the car to my tuner.
OK good to know. So is the IAT pigtail the one that's connected to the lid? My MAF pigtail only has 3 wires going to the MAF sensor.
