Installed mellings 295HV pump and Harmonic Balancer wont seat correctly
Does the Harmonic Balancer bottom out on the oil pump or slide thru the center hole?
Because I Installed Mellings 295HV pump and Harmonic Balancer won't seat correctly, checked the specs and it should go on without a hitch , but it won't seat all the way to correctly line up the fan belt! or the old seal marks.
I put the 295 next to the 295HV pump before installing and it was a little taller but Melling countersank the face plate bolts to offset the height difference, but does the Harmonic Balancer bottom out on the oil pump or slide thru the center hole?
and is it to much volume for the ON3 twin Turbo Kit?
Stacy
Stacy
LS1Tech Premium Sponsor
People usually shy away from high volume on single turbos and opt for high pressure.
Are you using a double roller chain also?
Are you 100% sure your crank gear is on all the way, the fron cover is completely bolted down, and your balancer is bottomed all the way?
The balancer butts against the oil pump drive/crank gear.
What timing set did you use?
I have the stock single chain
I've run the impact gun forever so i'm thinking its seated all the way.
Timing set is stock.
SO DO I NEED TO MILL A SMALL AMOUNT OFF THE Balancer ???
OR switch to a high pressure pump instead ?
Otherwise, either put the balancer in the oven for a bit or use a torch to heat only the hub then install it. Youll prob see it go on alot easier. A small amt of lube in the balancer and on crank can help also.
You need to use an install tool and not the stock bolt and impact gun. Good way to break the bolt.
I was going to grab a 150mm bolt, washers and bearing to install the balance tomorrow morning , I did heat it up to 175-190* and put a little anti seize on the balancer.
I don't want to bust off a bolt or jack up the crank.
so Im going to go to O'Reilly's and check out the difference in offsets on the oil pumps if the balancer rides on the pump gear!
so your saying the balancer should slide on with heat, proper tool and a little anti seize.
and that the 295HV only has larger pump gears not thicker gears stopping the balancer.
Thank You
tech@WS6store
for the help yesterday, I went to the Hardware store and got all thread and 1.5"x 3" pipe .... and what do you know ... it slid right on like butter.
tech@WS6store
Do not....i repeat....DO NOT put that balancer in the oven. You will more than likely destroy/distort the rubber, and when it comes apart while running will take out your crank and whatever else it happens to hit. Use a handheld propane torch and heat up the snout of the pulley, and it will install with nearly zero effort. Personally I don't like to use the threads on the crank snout for anything other than to bolt the balancer on.
Don't care how many people have gotten lucky, it's a bad idea. Like I said, if you want to do the heat method to install the balancer that's cool..... just heat up the snout of it, this keeps the rubber from getting super heated/compromised. You gain nothing but potential headaches by putting the thing in the oven.
You shouldn't even need an install tool while using a propane torch. When you get the snout of the balancer hot enough.....it just falls onto the crank.... no tool needed. I wish I still had the old balancer that I tried the oven trick with, speaking with live in the flesh experience here. One may get away with the oven deal, or he could end up with a real mess under the hood. Id rather not take the gamble.
