Lq4 horsepower estimate
Old 01-17-2018, 03:56 PM
88bluchevy's Avatar
Default Lq4 horsepower estimate
i have a 2005 lq4engine with Texas speed prc2.5 heads, comp cam 231/237.614/.621 at 113 lsa cam. It has Holley hi ram intake with ford racing 42lb injectors. Walbro 255 fuel pump. Upgraded trunion kit and ls7 lifters and we figure around 10.7 CR. Just curious as to what y’all may think it’ll make on motor before nitrous.
Old 01-17-2018, 04:03 PM
HCI2000SS's Avatar
Which PRC 2.5 heads?
Old 01-17-2018, 04:23 PM
88bluchevy's Avatar
Prc 5.3 2.5 heads
Old 01-17-2018, 04:44 PM
ragtopz28's Avatar
~450rwhp
Old 01-17-2018, 04:49 PM
HCI2000SS's Avatar
Ok I have those heads as well. The dyno number can largely be effected by the trans type and type of dyno, so I'll say anywhere from 400-450
Old 01-22-2018, 09:37 PM
rpturbo's Avatar
And location of the dyno, the cycle of the moon, and 100 other things.
OP it should feel pretty stout and make you smile when the exhaust sings!
Old 01-23-2018, 01:25 PM
wph351's Avatar
Will be interested in your results. I'm putting together a SBE lq4 with shaved AFR 205's and a btr stage 3 truck cam. Post up results if you get it dynoed. I'll do the same.
Old 01-24-2018, 01:00 PM
allblackedout5's Avatar
Depending on weather, trans and rear end its going through, and type of dyno.... as others have said anywhere between 400-450rwhp is great estimate. If I was a bettin' man I'd say 432rwhp. Just for *****.
Quick Reply: Lq4 horsepower estimate
