My 71 Chevelle LY6 swap project
Hi All
3 month ago I pulled the 454 from my 71 Chevelle and started an LS swap project, I think about that since 10 years and now it's time to do it.
Here basically what I chosen or purchased, I will try to post some picture and info as the project goes by and found some useful info and tips here on the forum
-Body & Chassis
71 Chevelle
12 Bolt rear diff with 3.73 gear
P285/70R15 BF Goodrich Silvertown
TH400 Full Reverse valve body that was already in the car, changed the torque an LS bolt pattern and 2800RPM Stall
-Engine
2012 low mileage L96 pulled from a Savana HD van
-Upgrade
Fitech Ultimate LS kit 750HP
Comp Cams Camshaft
Comp Cams Springs
Comp Cams Trunion kit
Summit SFI damper
ARP rod bolt
Stainless Works 1-7/8 headers
Griffin Aluminum Rad LS swap combo
Holley Rocker Arm Cover
Holley oil pan 302-2
Holley engine mount
Chevrolet Performance front accessory drive # 19257325
Here the list of item done, will probably add more later
-Body & Chassis
71 Chevelle
-Engine
-Upgrade
Comp Cams Camshaft
Comp Cams Springs
Summit SFI damper
ARP rod bolt
Holley engine mount
You might want to use either a 4L60E 0r 4L80E transmission to get a good overdrive gear with the 3.73 gears you have. Cruising will be SO much nicer with either tranny.
Is it normal that it took one week to post picture on this forum, I got a message last week that the moderator have to validate my picture before posting and still have now news yet........
Your post count is still too low, I think, to easily post pictures. You have chosen well on the Holley 302-2 oil pan but you might need the Holley one inch forward bias engine mounts to keep your transmission from hitting the floor hump. Have you taken a look at the thread below here on LS1Tech? It is very informative about your swap.
https://ls1tech.com/forums/conversio...m-preview.html
Rick
Rick
Rick
Rick
The holley oil pan 302-2 fit really well on my engine and frame
Great looking car!
Nice car, that indeed is a lot of tire. Looks good.
I hate to see a 454 get yanked for an LS. Ever think about spending a few grand on the big block? IMHO a big block is 10 times cooler in a muscle car than an LS. And nothing beats the power of one unless your going to go FI on the LS. Even still, a snotty big block is an experience.
Fitech and a blower on the old BBC.
I'm seriously considering running a single carb roots on my 68 big block suburban along with an FItech system. I already have an NA Fiotech system at home, just waiting to install. Like every other thing in the world with me the past couple of years. Numbers matching and want more power with changing it tooo tooo much.
Hi
Here some picture of my build, those are when I got my LY6 from the donor Savana van
Freshly removed form the 2012 Van
OEM intake removed and engine cleaned before paint.
