Zl1 supercharger
Old 02-17-2018, 11:51 PM
427BBV8's Avatar
Default Zl1 supercharger
anyone know where I can buy a used zl1 supercharger?
Old 02-18-2018, 12:09 AM
LLLosingit's Avatar
There are several on E-bay.
Old 02-18-2018, 12:21 AM
427BBV8's Avatar
theyre kinda pricey 1500$ just for the base of the supercharger seems rediculous
Old 02-18-2018, 01:21 AM
LLLosingit's Avatar
Look up LSA supercharger there are some that sell cheaper than that, They used to sell for 5-6 hundred but that was when GM was in the middle of replacing them and the market was flooded with them. I paid $1100 for a brand new one and $379 a new lid. The price has almost doubled on both in the last year.
Old 02-18-2018, 09:22 PM
wyattroa's Avatar
I would love to find those prices, but I have a feeling the prices will just continue to go up.
Old 02-19-2018, 10:32 AM
epix's Avatar
They will, GM requires a core now for the fix.. supply has drained up.
Just picked one up in person this past weekend from a main supplier of LSA superchargers and that's what he told me at least.
Old 02-19-2018, 10:48 AM
wyattroa's Avatar
Curious what did you get yours for? Lowest I have seen them is $1,100
Old 02-19-2018, 12:03 PM
The BallSS's Avatar
Jablowme has them listed on here all the time.
Old 02-19-2018, 12:53 PM
Jimbo1367's Avatar
Zzperformance has used for $1100 and rebuilt for $1499 Iirc
Old 02-19-2018, 02:24 PM
LS6427's Avatar
Brand New LSA from the dealer....at least my dealer.....is only $2,100. That along with another $1,000-$1500 worth of stuff....not bad for about 700 RWHP.
Old 02-19-2018, 04:14 PM
427BBV8's Avatar
my ls7 cracked and piston so I’m doing a forged ERL 6 bolt 1/2 inch stud 427 block with lsa heads for now (cheap) and a lsa zl1 lid blower trying to hit 800whp on e85 blower only.
i was told my ls7 accessory would work same as a ls3 vette but would need some machining on the pulley to make it fit. You guys think 800whp is achievable
Old 02-19-2018, 04:52 PM
LLLosingit's Avatar
I don't think you'll hit your goal of 800whp with a stock LSA supercharger and stock LSA heads. Stock LSA supercharger and good heads would put you in the 650-700rwhp range from what I've read, Add another 40-50hp if you have the blower/snout ported.
I wouldn't go with the LSA supercharger or heads with that engine, You'd be much better off with the LS9 supercharger and aftermarket or ported LSA/LS9 heads.
Old 02-19-2018, 07:43 PM
427BBV8's Avatar
was as told by my tuner a 427lsa could hit 800whp pretty easy I’m kinda doing the steps in intervals porting and all will come later
Old 02-19-2018, 08:29 PM
jimmyg's Avatar
I would be really surprised if you hit 800rw with an lsa blower. There is only so much power you can get out of a 1.9L . If I were you I would do some research and go with a blower that is capable of reaching your goals.
Old 02-19-2018, 11:07 PM
LLLosingit's Avatar
800 to the tire with those heads and smallish blower is going to be tough. Your heads will hold you back quite a bit. I would study some other builds and see what they made and what it took to get there.
Old 02-19-2018, 11:09 PM
LLLosingit's Avatar
Here is an article that shows what you're up against. http://www.superchevy.com/how-to/eng...y-last-725-hp/
Old 02-19-2018, 11:10 PM
brewster240's Avatar
i have one ill sell, where are you located?
Old 02-19-2018, 11:33 PM
427BBV8's Avatar
california text me 9254347099
Old 02-20-2018, 08:54 AM
427BBV8's Avatar
where is this! Lol
Old 02-20-2018, 08:57 AM
427BBV8's Avatar
725 crank hp
is about 640ish wheel not bad for a stock non cam lsa with that stuff a 427 a blower cam ported lsa heads ported blower and snout cold air intake and e85 should easily see 700whp I’ll be happy with that how bad is the heat soak problem?
